what cam would be best for me?
Old Apr 22, 2008 | 11:47 PM
loudNproudSS's Avatar
Default what cam would be best for me?
i want to get a cam for my car if it would be a good investment. i dont need a real aggressive one, i dont plan on doing any hardcore work to it, just a few little things to boost the power a bit. im getting an edelbrock performer intake, do i need to upgrade my carb for a cam? i have the stock 4 barrel Q-jet and it works fine. anyways what cam would be best for me? or should i leave it stock? i want a little lope to the idle, and hopefully a slight boost in power
Old Apr 23, 2008 | 07:09 AM
wiz kidd's Avatar
Default RE: what cam would be best for me?
i would go with a crane cams cam i think the part # is 100032
for that cam you dont have to do a tonne of work, check out crane cams on the net and you can search what you want, i think its the most common one out there
Old Apr 23, 2008 | 08:12 AM
88ss408's Avatar
yeah go with the crane compu-cams they are numbered 2020,2030,2040,2050 they work great with a computer controled car
as for the q-jet i would put in diffrent secondaries (ck rods are good ) for a little bit more power it should match up good with that intake
Old Apr 23, 2008 | 11:55 AM
thanks, im gonna look at crane's website (if they even have one, if not ill just check out Jeg's and Summit and stuff).
where can i find the CK rods carb secondaries?
i have another question about cams, a friend of mine has a built up 350 in his S-10, and he is telling me that putting in a cam will kill my gas mileage. but i didnt specify that i didnt want a real aggressive cam, and i think he assumes i mean one like he has where the engine almost stalls between "lopes". will a light cam effect gas mileage?
Old Apr 24, 2008 | 07:43 AM
88ss408's Avatar
i don't it should bother it that much give or take 1or 2 mpg
as for the rods your local dealer should be able to get them for ya
03vaderSS
Oct 2, 2014 08:38 PM
JoeD
Jul 15, 2014 10:00 PM
NYGiantsfan
Jun 19, 2014 12:30 PM
S.O.G.
Mar 9, 2013 06:59 AM
iJuanHD
Mar 24, 2012 12:02 PM
