Carbon Build Up?
Old Apr 24, 2008 | 06:37 AM
TommyBoy's Avatar
Default Carbon Build Up?
I recently purchased a 2006 Monte SS 5.3lV8 Supercharged and am having hesitation problems when I put the petal to the floor on start. I've added heet to remove any water & will add carb cleaner next. I will also try Sea Foam as I have seen posted on other topics. My question is, how long/many miles before carbon build up will appear? I hope this is my hesitation problem. I use premium gas as suggested and have tried several diff. stations.
Any Help?
Tom
Old Apr 24, 2008 | 06:40 AM
Cowboy6622's Avatar
Default RE: Carbon Build Up?
hm.... 5.3L Supercharged?
it could be an electrical problem. does it only do it when you first floor it? try changing out your plugs and plug wires, change your oil while your at it.
Old Apr 24, 2008 | 06:49 AM
TommyBoy's Avatar
Yes. But after I added heat the other morning after about 15 miles it quit. I don't know if it is water or just because the engine was warmed up. Since I bought it from the dealership it started and has gotten worse. I live in Northwester Wisconsin and I think the previous owner had it stored away for the winter. We still get cold nights and warming up in the days, thats why I thought it could be water. I guess if I can't get it to quit, I will bring it in & have a diagnostic run. It only has 18000 miles on it. Thats why I was wondering also about carbon?
Tom
Old Apr 24, 2008 | 06:56 AM
DEI Monte SS 04's Avatar
I don't think it is carbon with that year and those miles. Take it in and get it checked out let us know what it is.
Old Apr 24, 2008 | 06:58 AM
TommyBoy's Avatar
I will. Thanks & I'll let you know whats up.
Tom
Old Apr 24, 2008 | 07:09 AM
wiz kidd's Avatar
do you have any lights on on the dash board? doesn't sound like carbon on that new of a vehicle, but it is possible, how many miles on the car?
Old Apr 24, 2008 | 07:18 AM
ffej06montess's Avatar
Are you sure your vehicle is supercharged? I have never heard of one, but i would like too!
Old Apr 24, 2008 | 07:23 AM
wiz kidd's Avatar
could be something that was done aftermarket, and that could also be causing the problem
Old Apr 24, 2008 | 07:24 AM
TommyBoy's Avatar
No lights on the dash.
Old Apr 24, 2008 | 08:18 AM
TommyBoy's Avatar
It has the 5.3l V8 in it. I thought it said supercharged but I am not sure. I don't see any online that are stock supercharged so I could be wrong. I am new to sports car lingo & buying so Hmmm!
