6th Gen ('00-'05): turbo monte upgrades :)
Old Aug 13, 2012 | 02:21 PM
turbo monte's Avatar
Talking turbo monte upgrades :)
ok everyone i just bought a 1" gmr 7/16 pitch 3.52 gear ratio trans chain and gear set and a Meziere Billet Flexplate for turbo monte! i am in the process of possibly buying a gmr torsen diff as well and cartuning performances 3rd gear piston and trans pan adapter along with my turbo upgrade (t66, 3" dp's, 2.5" charge pipes, meth injection) for this winters project
now onto a few questions, anyone familiar with the 1" 7/16 pitch chain? im under the assumption there needs to be machining done for clearance? anything else need to be done to use the chain and torsen diff?
also i am having engine coolant and trans temp issues, i cant seem to keep it cool everytime i jump on it i see my temps spike like crazy. i need to find a way to keep her cool any ideas?
i am running a 180 degree t-stat and the fans are tuned to come on earlier as well. i also have an aftermarket trans cooler but dont seem to be helping any....
finally once i start this upgrade i will be selling all the used parts i am replacing:
7/8" 2.93 trans chain
hd diff
precision 61 trim t4 turbo (cartuning turbo)
cartuning 2.5" downpipes (upper and lower)
stainless plog
none of this is for sale yet but come fall/winter it will be
Old Aug 15, 2012 | 06:43 PM
TheMonteMan's Avatar
i dont know the answers to your questions, but im curious what this car has run with your current setup.
Old Aug 15, 2012 | 06:59 PM
I made 384whp and 352ft lb torque on current setup. If everything goes as.planned I am going to the track tomorrow for some 1/4 passes
Old Aug 15, 2012 | 07:04 PM
what do you have suspension and tire wise on the car?
Old Aug 15, 2012 | 07:39 PM
Stock suspension for now. I'll be running toyo proxi at the track
Old Aug 15, 2012 | 08:27 PM
goin to be tough to hook.
Old Aug 15, 2012 | 08:31 PM
I know lol
Old Aug 15, 2012 | 09:25 PM
Mr Grizzly Mint's Avatar
If you are familiar with VW they use air cooled engines. The underbody has plates to direct air to the engine. under your front facia you could attach a few air dirrecting plates to help cool the block. Also run a bigger radiator. Another thing you can do is ceramic coat your exhaust and turbo pipes. with all the turbo piping you are making more heat under hood then you should.
MonteCarlo04SS
Feb 15, 2025 10:41 AM
vikesfan
Jan 29, 2014 12:23 PM
04SuperchargeR
Jun 11, 2013 06:39 PM
taz7nads
Jul 19, 2012 12:28 PM
bama_z34
Nov 29, 2010 10:00 PM
