Info: Turbo for a 3400?
Old Dec 15, 2015 | 10:07 AM
AHart87's Avatar
Default Turbo for a 3400?
I was thinking about throwing a turbo on my 2004 Monte Carlo with the 3.4 v6, but I really don't know much about where to find one and what all I would need to buy in order to turbo it properly. If someone has information that would answer these questions that would be great!
Old Dec 15, 2015 | 04:44 PM
Brendocee55's Avatar
Old Dec 15, 2015 | 08:48 PM
The link Brendocee posted is probably your best bet.
For W-Body cars, like our Montes with a 3400, I don't think there is an out-of-box bolt on kit. You may need to adapt a n-body/grand am kit or custom fabricate your own.
Old Dec 15, 2015 | 10:55 PM
Yeah would be cool to see one of those superchargers that were made for the Grand Am Gt on a MC
Old Dec 16, 2015 | 08:47 PM
AHart87's Avatar
Alright thanks
Old Dec 23, 2015 | 05:25 AM
fatfig's Avatar
hey if you get it done can you send me pics and keep me update on this project....might want to do the same
Old Dec 23, 2015 | 08:38 AM
ThatKevinC's Avatar
IMO if you have to start a thread like this, you are no where near ready to turbo your car. Take your time, do your research. Learn about turbo's, how they work, supporting mods needed, etc. Then try and find threads, builds, and any other info related to the 3400 (even if it's from a different car). There's a good chance you'll end up having to build a custom "kit" yourself, but that's not a big deal (but it can get expensive). I knew nothing more than the basics when I built my big turbo car. I started off spending hours and hours a day reading on turbos. I spoke to a lot of people, and always made sure I was asking specific questions that couldn't easily be found online. No one wants to spoonfeed someone info. I slowly built up my parts pile and by the time I had everything, I knew enough to build the car.
Short list of what you'll need:
- turbo (pick one based off of your budget and power goals)
- custom turbo manifold
- wastegate
- custom downpipe
- custom intercooler piping
- intercooler
- blow off valve
- FUEL! (rails, injectors, high flow pump)
- custom oil pan
- engine management (ecu reflash, rrfpr, stand alone, or a piggyback)
- transmission? I think with an auto trans you're going to need to add a cooler, but confirm that with your research
Old Dec 23, 2015 | 05:23 PM
KCFITZ78's Avatar
fatfig,
What did you use to paint those aluminum pieces blue? I like it!
Old Dec 24, 2015 | 04:11 AM
fatfig's Avatar
Default blue paint
just clean the parts, then primer and regular spray paint i had in the garage, nothing special...i was installing new gaskets my oil and water was mixing. since i had it apart, i painted the parts....looks cool but no special paint that i used. thanks
Attached Thumbnails Turbo for a 3400?-imag0258.jpg   Turbo for a 3400?-imag0257.jpg   Turbo for a 3400?-imag0256.jpg
