tuning for l32 swap into 2003 monte ss
Old Nov 7, 2013 | 06:56 AM
z34phoenix's Avatar
Ok after looking at the file this is what im concluding: Please verify...
-you indeed have the 04 trans and gearing has been changed
-your running the 03 NA file
-all the security has been removed from the pcm.
if it is still the original PCM harness and BCM, i don't see why your key or security would cause this issue. further more, if it were security i would think it wouldn't start at all. that being said, you could set the security all back to normal and i don't think it would change anything. when i swapped from my DOHC to the 98 L36 and trans i did not change any of the security tables and it all runs fine. now im running with my topswap and it still is great. so i don't these files needed changing.
It has been a known issue with the 2003 trans only working with 03 pcm. it is possible that the 03 bin file you are using is not compatible with the 04 trans. I can send you 2002 l36,l67 bins and 04 NA,SC files as well. your pcm will not accept the 04 but they might be a good ref for you. your pcm should accept the 02 files if not you may need to swap pcm's
if that doesnt work, i would contact overkill as you get much more for your money vs zzp or intense.
Old Nov 7, 2013 | 02:36 PM
gtpshawty's Avatar
I was talking to intense they say they can do it for 175
Old Nov 7, 2013 | 03:04 PM
Mac7504's Avatar
Would an aftermarket alarm come into play with an of this? It shouldn't right?
I'm just starting to think when I order the SS kit I had planned on sending the PCM in to be flashed, to avoid the security relearn. However, I've heard of issues about getting incorrect bin files from certain places... Should I have them send me the file, have someone look it over and load for me?
Sorry for the hijack, I just don't want to end up with a PCM that won't work (have an 03).
Thebst696969
Sep 17, 2013 12:46 PM
abro22
Jul 26, 2011 02:24 AM
sickofsoyo
Jul 26, 2009 08:26 PM
tim_haha2000
Jan 29, 2009 10:00 PM
fever42
Jul 31, 2006 05:08 PM
