Transmission Pan Gasket
Old Mar 1, 2012 | 08:40 AM
Rellsun's Avatar
The old fluid looks pretty nasty so I wasn't sure which option would be better. Maybe I'll just drop the pan do the filter then change more fluid at my next oil change. Thanks guys
Old Mar 24, 2012 | 04:11 PM
Bait's Avatar
Originally Posted by Rellsun
[FONT=Verdana] 1st design 6mm bolts or 2nd design 8mm bolts. Not sure which I have but I'm assuming 2nd design.
You would only to replace the bolts if the washer has been torqued down to much and caused it to invert.
Old Mar 24, 2012 | 06:59 PM
DRuben's Avatar
Its (20) 10mm bolts going around the pan. I bought the filter and gasket kit from oreillys and the gasket looked like a crappy design so since mine was in good condition I reused it and so far so good. I actually did mines 2 days ago and had tranny fluid everywhere lol. The fluid looked brownish but I had no metal pieces or shavings just some gunky stuff on the magnet. The seafoam trans tune stuff is great! My shifts are smoother and I cant even feel when its going from 2nd to 3rd and I have a broken passenger engine bracket and busted motor mounts!
Old Apr 3, 2012 | 11:35 PM
izmouse's Avatar
I have 6mm bolts. The oil pan is 10mm.
Mouse
Old Apr 4, 2012 | 06:11 AM
DRuben's Avatar
Mouse
Your kit came with 6mm bolts instead of 10mm?
Old Apr 5, 2012 | 08:42 AM
izmouse's Avatar
No, when I got the SS it was missing 4 of the bolts. I had to find the right size, that's how I know....I started buying 7mm first, then had to go to a 6.
Mouse
GTX
Dec 11, 2013 11:03 AM
montechick
Mar 13, 2010 09:54 AM
Chevycarlo97
May 25, 2009 04:30 PM
shanefer
Apr 21, 2009 04:12 PM
koreancore
Jan 14, 2009 04:59 PM
