Transmission Issues?
Old Apr 14, 2011 | 04:54 PM
kingjames86's Avatar
Default Transmission Issues?
Hey Guys, so I'm not too sure if there is a better thread or this question I tried asking in a sticky but idk i that thread gets traffic as much so here goes:
So I went to take my '07 or an oil change for the first time since I bought it used last Nov. After the mechanic is done he tells me to "keep an eye out on the tranny" with no further explination...so my question is what specifically does he mean? What and when does the tranny mess up if it does at all, could he just be blowing smoke up my butt or is this a serious issue. I guess I just need clarification as to what you guys think he meant.
Also, 1 more question, is it bad to open the power steering cap when the engine is running? Whenever I press the gas pedal my car makes a weird sound and they told me it was something that got opened while the car was on, but i can't remember what it was...for some reason power steering cap sticks in my head...
Thanks in advance guys and gals
Old Apr 14, 2011 | 04:57 PM
The 4t65e-HD transmission is a known weak point in these cars. That's probably what he was telling you.
There was a power steering recall. Was it performed?
Old Apr 14, 2011 | 05:16 PM
I agree, he was telling you to keep up on the transmission maintenance or you could find yourself with a premature problem. Passing on some wisdom is all he was doing....
Old Apr 14, 2011 | 05:22 PM
Jon's Avatar
Jon
To often we find Transmission problems with the Monte Carlos. Iv been watching mine...i think it might be close to going...
Old Apr 15, 2011 | 12:18 AM
Hmmm...not sure, how will I know if it was performed? Idk if the previous owner did it
Old Apr 15, 2011 | 12:21 AM
What type of transmission up keep would u suggest? Btw, Thanks for all the replies guys!
Old Apr 15, 2011 | 07:19 AM
You should be able to call up the dealership and ask, it should be in the system with your VIN.
As far as the transmission, just keep easy on it and get the fluid and filter flushed every 30k or so.
mroseland
Mar 20, 2014 05:57 PM
clovis
16
Jan 30, 2014 03:09 PM
iMuf
Oct 15, 2013 02:23 PM
PontiacEd
Oct 25, 2011 06:49 PM
White05LT
Oct 1, 2006 02:12 AM
