6th Gen ('00-'05): Transmission fluid and filter change 2004 SS
Old Sep 3, 2017 | 08:37 PM
DAVESS2002's Avatar
Default Transmission fluid and filter change 2004 SS
This morning I changed the transmission fluid and filter, and upgraded with the ZZP shift kit. I also got a new gasket and Dorman pan with drain plug to make for easier changes in the future. I went with the Dextron VI fluid. Cheapest I could find was from ZZP around $24 for 4 quart container. I ordered 2 of those and the shift kit which includes the filter, seal and several shims that go on the accumulator piston rods. I also added some heavy duty neodymium magnets, two on the pan and two button sized ones on the filter to trap any metal fragments. Took about two hours to do everything and got stuck in a rainstorm but got it back together and running good ! Of course raining all day so was not able to test it very much, a drive around town in the rain had the traction control working!
Old Sep 9, 2017 | 08:16 PM
Congrats on the Fluid and Filter change! As long as you do regular changes, it should be all good.
Old Sep 11, 2017 | 09:56 AM
coolhand's Avatar
How do you like the shift kit? A noticeable difference? How did you set the shims?
Old Sep 11, 2017 | 07:26 PM
DAVESS2002's Avatar
I used the recommended 2/4" inners and 1/2" on 1-2 and 3/4" on 2-3 but not very noticable, although it seems to shift quicker but there's no bang like on the shift kit in my old car...
Old Sep 13, 2017 | 02:26 PM
coolhand's Avatar
Quick shifts are good, banging shifts are not so maybe it's better for tranny life.
Old Sep 13, 2017 | 07:46 PM
Nice, don't see that you were doing a filter / fluid change and calling it a day. You did everything right. A pan with the drain plug, sweet, that is the only way to roll. DEX VI fluid, temperature is our tranny's enemy, VI handles it the best, awesome! Love the magnet concept, stopping filaments from being pulled back into the system. I epoxied (aluminum pan) a powerful magnet inside my trannys pan by the drain plug area and another big build did the same to his. Smart move, what will it hurt, nothing. As they say "A job worth doing is worth doing right".
