transmission cooler
do you beat the hell out of it all the time? If so, then yes I would add a cooler. Heat is one of the transmission's worst enemys. On all of my automatic performance cars, I always added an external cooler. If you add one, you will still use the factory cooler. IIRC, you take the output of the factory cooler, and hook it to the input of the external cooler. Then take the output of the external cooler, back to the transmission.
i have one on mine it loves it. the best investment on helping the trans last the good thing is the preventitive mant on it will take longer to let the fluid drain. when doing the drop pan and all but it is good in the long run.
JuniorCar
22
11-03-2014 11:51 PM
cxt35
01-06-2013 10:14 PM
montecarlocrazy
09-18-2010 08:17 PM
Joe Thomas
06-08-2009 09:23 PM
