Trans. Help!
Old Nov 2, 2007 | 09:54 AM
Monte's Avatar
Default Trans. Help!
So I have a !985 SS and as I understand it aTH350 would work better then the stock trans with a 350,butI keep seeing itsavail in short tail or long tail. Which one do I need? Thanks [/align][/align]Peace,[/align] Monte[/align]
Old Nov 2, 2007 | 10:17 AM
Default RE: Trans. Help!
[align=center]
Hi Monte, Click on the below link & it might help find your answer. Good Luck `Space
http://www.transmissioncenter.net/gf...ssmembers_.htm [/align][align=center]If you can't find it, be patience, & I'm sure a member will answer : )[/align][align=center]GM Performance Transmission Parts[/align][align=center][/align]
Old Nov 2, 2007 | 04:31 PM
88ss408's Avatar
you my friend need a short tail trans and if you are going to put a 3spd in a 4spd car you will be needing a crossmember that fits the th350
Old Nov 5, 2007 | 07:09 PM
Monte's Avatar
Thanks for the helpguys Iappriciatit, forgotI asked and was goin toask again, would you say Id be better off justinvesting the crossmember money into a 4 speed trans.Thanks again guysand sorry it tock a min. for me ta get back to ya,ooops.......
Monte
bigworm
Jul 4, 2010 06:45 AM
blackbeauty89
16
Mar 3, 2010 10:11 AM
wschampcubs08
Feb 22, 2009 10:34 PM
Jdevon708
Jul 3, 2008 07:49 PM
1 Bad SS
Nov 13, 2007 06:53 PM
