Trans Fluid: Valvoline DEX/MERC III
Old May 31, 2012 | 01:46 PM
04IntimidatorSS's Avatar
Default Trans Fluid: Valvoline DEX/MERC III
Im changing the trans fluid soon and Im sticking with DEX III, just want to know what fluids people are using...
Valvoline #VV353
Trans Fluid
Old May 31, 2012 | 04:53 PM
MAMONTE's Avatar
If I was you I would switch to Dexron VI. It's far superior to the old Dextron III, it last longer, it's semi-synthetic, or can be purchased a s a full synthetic. Its lower viscosity, therefore will improve fuel efficiency.
Valvoline makes a full synthetic Dextron VI product, I use it in my Monte.
Dextron VI is full compatible with Dextron III.
Also, note that NO Dextron III product is licensed by GM any longer, therefore you have no way of knowing the product actually meets even the old Dextron III spec, per GM's old license. For all you know the oil company has left out an additive or altered the formula from the original Dextron III formula. GM recommends Dextron VI for not only newer cars, but as a replacement to Dextron III.
Hope this helps a bit.
Old May 31, 2012 | 08:10 PM
x2 Dexron 3 is an outdated formula. Dex 6 is the new formula and 100% compatible.
BadSSeed
Apr 30, 2014 02:53 PM
mwjames
Nov 1, 2011 06:54 PM
rpd709
Jul 18, 2010 02:38 PM
echolmberg
Oct 22, 2008 12:17 PM
rchurch
Mar 17, 2008 04:25 PM
