Antifreeze gone?
Old May 28, 2012 | 05:15 PM
iamjoshz's Avatar
Default Antifreeze gone?
I cant tell if theres a leak or what. I have no puddles or even drips. Ive let the car run and looked for drips but no luck. It doesn't over heat but obviously gets a little hotter when its running and just sitting still. The car engine seems to be very hot though.. Ive looked all around the engine and the hoses seem to be damp.. ive tried to smell em and there really isnt a smell to them. also sometimes ill see parts of the engine compartment with spots of something wet.. assuming its antifreeze? I can also see some antifreeze underneath the belts looks like its sitting in a part of the frame.. if that makes sense. I dont believe its leaking out of the radiator..
Any suggestions?
Old May 29, 2012 | 08:28 AM
Any smoke coming from the exhaust?
Old May 29, 2012 | 04:49 PM
iamjoshz's Avatar
No smoke at all. I did find a drip today under the driver side, looks like its coming from the water pump?
Old May 29, 2012 | 04:59 PM
Water pump is on the passenger side...
Old May 30, 2012 | 03:22 AM
iamjoshz's Avatar
I wrote that wrong I meant passenger side lol sorry
Old May 30, 2012 | 08:31 AM
There are also elbows that like to fail on the passenger side too.
If you can't find it, get the system pressure tested so the leak can be found
Old Jun 1, 2012 | 03:35 PM
iamjoshz's Avatar
Good advice, thank you.
White06MCSS
Oct 9, 2008 06:32 AM
jasonmcr
Feb 27, 2008 07:43 PM
Sir Monte
Feb 20, 2008 08:08 PM
hotrodss24
Dec 24, 2007 09:58 AM
87lsman
Jun 6, 2007 01:56 AM
