Tranny Issues?
Old Nov 19, 2011 | 07:01 PM
hollf1's Avatar
Default Tranny Issues?
I have a 2002 Monte Carlo SS. It has now 75,000 miles on it. It was been shifting rough (slipping) into 2nd and 3rd gear for over a year. Just a few months ago is started getting bogged down when I accelerate at 30-50 miles an hour. It doesn't hesitate all the time. Finally just last week it stalled for the first time. I noticed this week when the car is idling the rpm's drop for a split second sometimes. Think of it as a negative spike. I think this is what caused it to stall.
Has anybody experienced these symptoms? How worried should I be? I am planning on getting one of the newer Camaros, I just hope this car can last until then. Thanks.
Old Nov 27, 2011 | 02:40 AM
dallasperez92's Avatar
I'm having the same issue on my 2000 SS Pace Car edition... haven't done anything as far as repairs just yet and have yet to stall. A friend of mine actually had the same issue with his mustang and it revolved around a fuel line issue. Beyond that I have no idea
Old Nov 27, 2011 | 02:42 AM
nitehawkjcb's Avatar
It's probably the solenoids in your tranny going bad. Very common with these transmissions. Have your SES codes checked, you may have a P1811. Try changing your fluid & filter, it may help... Otherwise, you got some work to do.
Old Nov 27, 2011 | 09:43 AM
03SSLE's Avatar
Have the flow of your cat converter checked. I was having similar symptoms with my '03 and the cause was a partialy plugged cat. After installing a new downpipe/cat the bogging went away and the tranny now shifts as it should.
TheVille87
May 10, 2014 11:28 PM
Red Nightmare
21
Mar 25, 2013 04:06 PM
Gib DTD
May 14, 2010 11:31 AM
slinkeey
Feb 3, 2009 10:33 AM
314boi
Mar 13, 2007 02:10 PM
