Tranny flush
Old 03-12-2013, 06:03 AM
I believe it's a little under 8 quarts of trans fluid after the filter change.
Old 03-22-2013, 07:12 PM
Originally Posted by ZIPPY02
This is a cheap upgrade I like. It is a new tranny pan and it has a drain plug, so the next few times you replace your filter and fluid it is not such a sloppy mess removing the fluid as you lower the pan.....
I have heard about the tranny flush thing too, about it making trannys fail. If the fluid is really old replace the 8 qts or so when you do the change with cheap fluid and then run it for a few miles. Then drain it all again and replace with the 8 new quality Dexron VI fluids. This way your swapping out i would bet 75% of the old crappy fluid. See the drain plug pan would work here already. Get a NAPA filter with new gasket.
LINK TO NEW PAN WITH PLUG BELOW:
Dorman 265 814 Transmission Pan or Drain Plug | eBay
Darn, I wish I had this link a while back. I bought the same pan off of ebay for $52. I plan on changing my fluid again soon and putting this pan on. I used Valvoline Dexron VI the last time I changed it.
Wayne
Old 03-22-2013, 09:37 PM
Is this what ZZP sells?
ashleymc34
30
11-01-2009 10:03 PM
Evil03SSCarloGuy
04-25-2008 12:05 PM
monteman05
03-07-2008 04:52 PM
04MonteLS
10-28-2005 10:27 PM
01whitess
08-27-2005 02:43 AM
Quick Reply: Tranny flush
