tpi in 86 monte carlo ss
Old Dec 7, 2006 | 12:54 AM
zhian43006's Avatar
Default tpi in 86 monte carlo ss
i have an 86 monte carlo ss and i also have an 85 camaro with tpi i wrecked the camaro what are the steps to putting the tpi in the monte carlo what all do i need off the camaro and also i found this wire harness on ebay would this help me out alot?
Harness Features:
All relays and fuses are included
Only High Quality GXL wire used for protection from heat.
Fuses and Relays for:
A/C compressor
Fuel Pump
ECM, Coils & Injectors
MAF
O2 sensors
Transmission including Back-up Lamps
Wires to be spliced in from the body harness and engine harness are all labeled for ease of use.
Old Dec 25, 2006 | 02:11 PM
djhixter's Avatar
Default RE: tpi in 86 monte carlo ss
if that harness is for the tpi setup it should be fine. everything you need to do this swap is basically under the hood on the camaro will need to go on the monte to include the electric fans.
Old Jan 27, 2007 | 10:43 AM
steptoe's Avatar
The Monte Carlo uses a computerized electronic feedback carburetor system. The TPI does not. It is a totally different system and will not work unless you change over everything (wiring harness, computer, sensors, etc) from the Camero. Lots of work but can be done. Good luck.
omgwtfdood
Apr 8, 2011 08:42 PM
Richie F
Apr 30, 2009 10:58 AM
Richie F
Jan 22, 2009 06:40 AM
brian923
Apr 15, 2008 08:25 PM
jac1599
Sep 22, 2006 01:58 PM
