tpi in 86 monte carlo ss
i have an 86 monte carlo ss and i also have an 85 camaro with tpi i wrecked the camaro what are the steps to putting the tpi in the monte carlo what all do i need off the camaro and also i found this wire harness on ebay would this help me out alot?
Harness Features: All relays and fuses are included Only High Quality GXL wire used for protection from heat. Fuses and Relays for: A/C compressor Fuel Pump ECM, Coils & Injectors MAF O2 sensors Transmission including Back-up Lamps Wires to be spliced in from the body harness and engine harness are all labeled for ease of use. |
RE: tpi in 86 monte carlo ss
if that harness is for the tpi setup it should be fine. everything you need to do this swap is basically under the hood on the camaro will need to go on the monte to include the electric fans.
The Monte Carlo uses a computerized electronic feedback carburetor system. The TPI does not. It is a totally different system and will not work unless you change over everything (wiring harness, computer, sensors, etc) from the Camero. Lots of work but can be done. Good luck.
