Top Swap write up needed
Old May 31, 2011 | 07:13 PM
while others say that the l36 pcm will relearn itself after about 300-400 miles with the swap.
Whoever told you that is definitely wrong- as mentioned above- what about the hard coded values for the sensors/electronics you've changed- you're running a 2 bar instead of a 1 bar MAP; different injectors; and a different TB/MAF sensor. I'm sure it'll run on an L36 pcm since the engines are virtually identical, but fuel trims will be all out of whack due to the 3 things mentioned above.
I'd still like to know your opinion on the subject, a $600 dyno tune vs. a $225 box tune, would the performance difference really justify the price?
Where are you getting the $225 from? Looks like ZZP's pcm is $125 + $20 for the top swap tables.
Even at that- have you considered getting your own tuner? Powertuners have been going used for $250 and less for awhile now- and the top swap 'tune' isn't that hard since you're just combining stock tables from an L67 with some of your stock tables (ie transmission settings).
Old Feb 5, 2013 | 10:46 PM
MONTE2000SS's Avatar
I was thinking of going with hptuner and it seems like a lot to learn but if I get a canned tune and then start to tweek with a hp tuner wouldn't hat be the easier way to at least ge close then start ... Is this the way to go ..which way did you end up going
Old Feb 6, 2013 | 12:40 AM
nitehawkjcb's Avatar
As mentioned, a tuned PCM is required. IDK if it's worth THAT much more to get it dyno tuned... But I'll get mine dynoed one of these days. My honest opinion: Invest in a scan gauge, get a PCM from a vendor and see where your KR is. Otherwise you're gonna end up needing to have the car towed to get it dyno tuned anyway.
BrandonStebing
Mar 13, 2014 08:49 AM
BrandonStebing
14
Feb 28, 2014 10:54 PM
LW57912
Mar 7, 2013 02:48 PM
my00monte
33
Apr 4, 2011 06:37 AM
monteriderLS
Aug 7, 2006 02:53 PM
