Top Swap Question
Old Sep 19, 2009 | 11:58 AM
paintballerr78's Avatar
Default Top Swap Question
I found a supercharged top swap kit that includes
heads
valve covers
lower intake manifold
injectors
fuel rail
supercharger
TB (no maf)
vac lines
idler pullies
brackets
balancer
for 700
It says i would need
gaskets, fluids, harness upgrade, and torque to yeild bolts
How much would it cost for these additional parts. Also is there any other parts i would need
Old Sep 19, 2009 | 03:07 PM
The harness adaptor is like $20 from ZZP- as for fluids, gaskets, and bolts- call around- its gonna vary by what brand you go with. Or you can go on ZZP's site, or one of the other Wbody sites and price the gaskets yourself.
If you bought all the parts for $700 shipped- I'd probably budget $1k just to be safe- then it depends how you do the pcm- you're going to have to have yours retuned to work with the new parts.
Old Sep 24, 2009 | 11:48 AM
03carloSS's Avatar
heads
valve covers
injectors
fuel rail
supercharger
TB (no maf)
vac lines
idler pullies
brackets
balancer
for 700
Where did you find this kit?
Old Sep 24, 2009 | 11:53 AM
03Monte's Avatar
you can find that very same kit at morad parts for around the same price. they can also get the harness, gaskets, and bolts to go with it (for an extra cost)
e-mail erik at sales@moradpartscompany.com
Old Sep 24, 2009 | 09:51 PM
If i were to buy the whole m90 kit from zzp. I would get some rebates from the pcm core charge and that wouldnt i. So it wouldnt cost at much as it says correct?
Old Sep 25, 2009 | 12:04 AM
03Monte's Avatar
Thats really a question for ZZP.
Old Sep 25, 2009 | 05:28 AM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
i got that kit. the entire kit from zzp minus your cores is around 1900ish. since you dont have a blower core (400 i believe) you'll get charged that. best bet, go to clubgp and find a good condition blower should be somewhere around $150 and send it in as a core, save yourself around $250 bucks. the kit is more expensive from zzp, but its less labor intensive. if your doing the install yourself, do a full top swap and save the cash. if your going to have it installed, it'll work out to be cheaper to do the kit from zzp.
Old Sep 25, 2009 | 07:25 AM
sprfrk2005's Avatar
i got my kit from morad for 700 plus shipping i got the fuel ingector clips and the wire harness from them also paid about 1100 for the parts shipped, i got lucky and have a mechanic that did the installation for a measly 250 bucks and my father-inlaw works for advance auto parts so got everything done for bout 1600 with pc tunned
Overdose666
Nov 19, 2010 04:12 PM
Pure2sin
Oct 15, 2010 10:41 PM
Enzo354
44
Sep 27, 2010 08:12 PM
Wilco
15
Oct 26, 2009 02:30 AM
