Top Speed
Old 02-02-2008, 09:49 PM
Default RE: Top Speed
what does the 04 supercharged top out at? i got to about 120. stock no mods
  #32
Old 02-05-2008, 07:01 PM
is the pcm the little module found under the hood in the bottom of the airbox? i have a 2001 monte carlo ls, 3400
  #33
Old 02-05-2008, 08:16 PM
RocknSS04's Avatar
I've had my Indimidator SS to and held 125 stock. Since the mods, I hit 135 and was still going when I back down. Caught some cross wind. I think it will hit 140. I intend to find out this summer.
  #34
Old 02-06-2008, 08:12 PM
is the pcm the little module found under the hood in the bottom of the airbox? i have a 2001 monte carlo ls, 3400.... i wanna send it away to be reflashed
  #35
Old 02-07-2008, 05:53 AM
That's the PCM indeed. Make sure you disconnect the negative on your battery before you disconnect the PCM. Your car will not function without it. I'd suggest you pick up a stocker from a wreckers, and send that in instead, that way you have a spare.
I've been 160+ a few times... with room left to go, it's dangerous past 120mph, and I won't try it again, especially with my 3.29 gearing... running in 4th gear at WOT is tranny suicide.
  #36
Old 02-10-2008, 04:36 PM
ok... thanks
MyIntimidator
12-21-2010 05:54 AM
BeachBumMike
02-27-2008 07:24 PM
ajsbengals
15
10-07-2007 09:37 AM
Yellow_Monte
06-16-2006 12:26 PM
Quick Reply: Top Speed
