Tinny Clicking Sound When I turn Right
Could just be your intermediate steering shaft.
Go under your steering wheel and take off the plastic piece above your gas pedal and brake. Pull back a black rubber boot and you should see a blueish greenish circle. Inside there is a knuckle for your steering. Shoot it with some white lithium grease and turn the steering wheel a little, shoot it some more and see if that helps.
i have a 99z34 also but i hear a clicking sound(like something tryin to lock and then unlocks) but its only when i press on the brakes. Like when im slowing down before i go over a speed bump or train track then i hear the sound 1-2 secs before i hit bump. Sometimes i also hear it when i start the car and shift into reverse it will make a 2 click sound; Or before making a left or right turn. Its either 2 clicks or 5 clicks that i hear and it happens randomly.
Hi! I wanted to follow up to everyone. It was in fact my starter! I still don't understand the whole technical issue, but apparently the piece inside of the starter was hitting something. It only happened when I turned right because of the where it is positioned and the weight shift.
Starter was replaced and VOILA! NO NOISE!
Peter W. Ruby Sr.
Nov 11, 2014 07:37 PM
shad420w
Apr 7, 2011 10:31 AM
motoguy1012
Jun 24, 2007 07:41 PM
