Throttle Body Spacer?
Old Oct 11, 2011 | 08:32 PM
kessey's Avatar
Default Throttle Body Spacer?
Hey guys, do you think this Throttle Body Spacer is a good buy for me? It would go in my 2001 Monte Carlo SS. Any gains? Losses? Feedback would be greatly appreciated. Thanks!
AIRAID Throttle Body Spacer for 3.8L Series II V6 - MCUNDER - PFYC.com
Old Oct 11, 2011 | 08:52 PM
zipper's Avatar
Waste of money. I think the only thing that would be good about getting a t/b spacer is that you could adapt a nitrous system to it. If you're not going to get that, you will get absolutely no hp gains from it. I would like to see you spend your money on something that will actually gain hp.
Edit: I just clicked on the link and they want WAY too much money for that thing. ZZP would sell you one for a fraction of the cost: ZZ Performance
Old Oct 11, 2011 | 08:57 PM
Jomao_o's Avatar
You gotta do a bit of reading on here before you start buying random parts.
Old Oct 12, 2011 | 08:09 AM
z34phoenix's Avatar
yup. we will save you lots of money and get your car running fast. there are a lot of gimmicks out there and some tricks that work on other cars wont work here. so read thru the "modding your 3800 safely" guide and you should find all that you want.
for starters the things i would suggest are:
#1 is remove the U bend in the exhaust just behind the Cat. ZZPerformance.com, Wbodystore.com all sell drop in replacements or a local shop can fix it. this is a major restriction and needs to go.
2nd is a cold air intake. you can save a bunch of money building one your self.
3rd save money and get a HV2 or HV3 from ZZP it is a drop in replacement for inside your intake manifold. will be a major improvement.
these will get you started.
Old Oct 12, 2011 | 08:27 PM
Zen's Avatar
Zen
Listen to theses guys.Most throttle body spacers do nothing but waste money.A carb spacer is a different story.
Old Oct 12, 2011 | 09:05 PM
xxtheshockerxx's Avatar
RED DEVIL
mine just makes a noise...didnt notice any power gains from it...good thing it was cheap
inssanity21
FWD Tech Guides '95-'07
26
Jan 11, 2012 06:03 PM
3800monte
Feb 4, 2008 09:20 PM
MadelynsDaddy
Aug 10, 2007 12:24 PM
Bml97MC
Apr 1, 2007 03:12 AM
2000_BLACK_SS
15
Aug 29, 2006 02:20 PM
