is there a S/C for my 95 Monte'
Old Jan 20, 2008 | 02:10 PM
F.W.L.R.'s Avatar
Default is there a S/C for my 95 Monte'
Does any one know if there is a Super Charger or a turbo for my 95 MC?
Old Jan 20, 2008 | 03:15 PM
lav74's Avatar
Default RE: is there a S/C for my 95 Monte'
What engine to you currently have, the 3.4 DOHC(Z34), or the 3100 (LS).
Being a '95, you're going to have some problems trying to tune it with a power adder. Honestly, you're better off getting a 98/99 Z34, and doing a top swap with the supercharger, or even a whole L67 swap.
If you want to keep your '95, it's ALOT of work to swap to a 3800 supercharged engine, since you also have to convert to ODB-II for the PCM to be tuned with the software out nowadays. See bumpin96monte's post on his '96 LS swap to the L67 in the mymonte.com forum:
http://mymonte.com/discussion/index.php?showtopic=22077
First step, do ALOT of reading, and get a real good grasp as to how much work is really involved in such an endeavor.
Good luck, and let us know if you have any questions.
Old Jan 20, 2008 | 04:10 PM
88ss408's Avatar
if you have a ls model with 3100 there is alot of things you can do !!
if you have a 3.4 dohc there is not much you can do
Old Jan 20, 2008 | 06:40 PM
F.W.L.R.'s Avatar
its the 3.4 but i got the car form my grnadma a long while ago. the car itself is crap. i might just buy a new one.
Old Jan 22, 2008 | 05:15 PM
z34phoenix's Avatar
SC is a big project for a DOHC.... if you go turbo your better off
your tuning options would be hinderend...for best results you would need to swap to OBD2 or down grade to a 91-93 pcm and harness to run obd 1 the you can get a chip from 60degreeV6.com or if your obd2 then get a DHP powertuner.
other then that your looking at stand alone fuel and spark managment systems... if your staying low boost you could possibly pull of a turbo. but for more then 7psi you need to do work to the pcm or go stand alone to be safe and not toast the motor.... then you have the issue with the trany....
97 dohc harness and pcm is the best option then you can run the 4t65 trany from the later years that is much stronger. will still need a tuner but this will be the strongest most relable setup.
Old Jan 22, 2008 | 05:24 PM
mrl390's Avatar
I emailed DHP and they are all out of the Power tuners. Its a shame cause I wanted one for my car. I guess HP tuners is the only option for a 3.4 DOHC tuner now.
Old Feb 10, 2008 | 12:51 AM
ParrottZ34's Avatar
Thats cuz they discontinued them
Old Feb 10, 2008 | 01:01 AM
ORIGINAL: lav74
They finally put my walkthrough in a separate thread- this is more of a nice step by step walkthrough:
http://mymonte.com/discussion/index.php?showtopic=23142
If you do decide to go with an L67 swap- it really wouldn't be that much worse. You'd use the engine wiring harness for a 98/99 monte, so that upgrades everything under the hood to obd2- I believe the only thing you have to do is run the correct new wiring inside the car to your obd port under the dash. The rest should be just as described above.
Not sure if you're even considering that route, just figured I'd give you some more info in case you do decide to go that way, since it would probably be cheaper and easier than doing a s/c on your car, and cheaper than doing a t/c.
Old Jan 23, 2011 | 03:00 PM
mrl390's Avatar
How does that have anything to do with this topic enough to bring up a 2 year old thread? Try starting your own thread instead of bringing up a 2 year old unrelated thread to ask your question.
iMuf
Mar 12, 2020 06:56 AM
dirt mod
Oct 8, 2013 02:19 PM
drjesus616
Aug 30, 2010 11:17 AM
Mike03R1
Aug 4, 2010 11:25 PM
BeachBumMike
May 25, 2008 12:12 PM
