Supercharger life?
s/c oil
.......Some of the people on here do have a small pump but most of us
use a old pump spray from a empty cleaner bottle like 409 for instance. After removing the plug with a hex nut driver......insert the
straw end of the trigger pump and spray into a jar or something simular. The old oil will be brown and kinda stinky........
https://montecarloforum.com/forum/sh...hanging&page=2
Awesome, GREAT information, Thanks! I'll be picking up some S/C oil from either ZZP or PFYC... I appreciate the help!
The next important question for me: what is kind of oil on a supercharged engine with 50K miles? I want to do the oil change myself (this will be the first oil change since i have purcahsed the car). I did it a handful of times on the LS, but this a S/C SSand it is a performance car and I want better quality all around.
wrdn76
I have an o4 ss two problems, separate controls for a/c and heat pass. works fine drivers side only heat, any ideas? the other is I just got this car drove it like 50 miles got home smelled hot oil smell lift the hood small amount of hot oil smoke like maybe valve cover leak? any ideas?
@WRDN76: Make a new thread; you're posting in a thread that's almost 2 years old and talking about changing supercharger oil.
To save you some time, you can click the link below and it'll take you right to creating a new thread that will appear in the "General Tech" section of the forum.
https://montecarloforum.com/forum/ne...=newthread&f=8
