Supercharger for 03' SS
#41
With the cost of head gaskets, manifold gasket, supercharger gasket, fluids, throttle body gasket, you're going to be at at least $600 IF you can find quality junkyards parts to use. That's not factoring in the cost of your necessary tune, too- figure you're going to pay someone at least $100 (or spend a few hundred yourself for HP Tuners). I know plenty of folks who have top swapped, thinking it was going to end up being a few hundred dollar investment, only to find themselves nickled and dimed into much more.
Really, as I said above- I've seen most of the top swap parts go for next to nothing- and many people are willing to give some stuff away for free because its borderline wortheless (like an L67 balancer, stock fuel rails, tensioner and front end pullies, stock L67 TB, etc)- I know I've personally thrown out a L67 balancer (and flex)- and a set of stock rails because I couldn't get anyone to even pay $5 + shipping. Also, with gaskets, a lot of times if you watch long enough, you'll find people that were collecting parts for a build and have to sell everything due to a bad situation- and so sometimes you can score gaskets NIB for 20-50% off the stores depending how desparate they are for cash. clubgp's for sale section FTW
You make it sound way too easy. I'm sure after tuning a few dozen cars it's no problem (with access to a dyno and a wideband), but for a novice it's a daunting task and one that I'm not interested in tackling.
#42
for future searchee's, the new NGK plugs did not eliminate the cold start issue's altogether, but it did stop my misfires by a lot during cold startup. used to see around 40, now only see a number under 10 before the counter resets.
edit: been 2 days, which equals 2 cold starts. both have been fine no loopy idle. maybe it did go away with the new plugs. i also swapped out my coil packs to MSD yesterday too. give them a shot see what happens. the most my idle loops is maybe 2 or 300 rpm, not major at all considering it used to virtually stall out.
My SS M90 kit is on- I'm running a staggered setup with Autolite 104s in the end cylinders and Autolite 103s in the center (this is a proven setup on L67s)- the car is firing right up for me each time (on the stock L36 PCM- ZZP shipped me the wrong PCM).
marcello7x
12-16-2006 02:41 PM
