super charger
have a o4 SS with the 3.8l eng.;;my landloard said he has a wreaked 3.8l with a super charger on it;;the 2 eng[besides one having super charger and mine not having]looks to be same;;is there a chance i can take the supercharger off buick and put on my engine and if can what all else would need be doon if anything to do it and it perform andrun good???
if not recomended to just do supercharger on my engine in monte then can i put complete super charged eng out of buick into monte?i'm looking only for a bolt in swap;;don't won't to chop/cut/butcher my car doing it..want to look factory and run as good as a factory super charged monte ss does....anything else needed done as for ECU AND OTHER ELECTRONIC CONTROLS???
There's a bit to a "top swap. I know you need heads, lower intake, the super charger, throttle body, injectors, should grab the coils (L67, Supercharged, coils are a bit different then the L36 non-Supercharged coils).
Also, I believe the compression ratios are different between the L36 and L67, requiring you to get a custom tune.
There are some members here who have done "top swaps" (Z34Phoenix being the most recent). I personally think you might be best doing an engine swap.... You have the complete donor car available.
If you swap the entire drivetrain, you will need a PCM tune as well. If get the engine and transmission from the same donor car, take the PCM and I believe it should just work (as the PCM from the donor has the tune you need). If you only take the engine, my guess is the trans you have vs the donor car are geared different, the PCM will need a custom tune for that.
Also, if you use L67 on a transmission originally set up for an L36 (I believe goes the same for a top swap), be prepared to eventually blow the trans and need a stronger one (I would recommend if that happens, contact Triple Edge Performance).
first you need to see what engine is what. what year buick is it? IIRC you should have a series 2 NA 3800 aka L36 depending on the year the buick may have a series 1,2,3 engine.
Next either way you will need to do tuning/ mail order PCM. the the vin in the pcm must match the BCM, so the buicks pcm wont just drop in your car. the vin will need to be changed. If you topswap you will need to do more work then just tuning. because of the higher compression, you will need headers and possibly rockers to safely run the stock 3.8" pulley.
for reliability, swapping the engine and trans will be making your car basically a SC SS like you said you wanted. you will need basically everything from the donor car. axles, trans, engine, harness, and pcm. the pcm will need to be updated with your vin so that it communicates with the rest of the car. I suggest the harness as the SC engines have different MAP sensors and a BBV solenoid. these harnesses can be purchased and added in, but if you have access to the entire car, you can save yourself the $40-50.
prob the easiest way to do the swap would be to unbolt the strut towers and then lower and unbolt the engine cradles,roll them out, and swap them that way.
Zzperformance.com will tell you. They sell an L67 supercharger kit for the L36. And no you will not need heads etc, thats the old way to do it. Zzperformance (the #1 3800 performance shop/website in the world) figured a way and it gives more horsepower then the L67 because the L36 is higher compression.
