Starting to Mod my monte.
Old 06-25-2009, 02:12 PM
2003supersport's Avatar
Photobucket
Monte Of The Month -- May 2009
TB (no maf)
correct me if im wrong, but isnt a MAF pricey vs. the cost of a used TB with all sensors?
i'd definately look into finding a replacement with all sensors...if your buddy can port the inlet then upgrade.
Old 06-25-2009, 06:21 PM
You can get a new 85mm external upgrade one for cheap- I got one off ebay from an LS2 for like $20.
Since his tune needs to be customized anyways for a regular 4t65 w/ an L67, its just a matter of copy and pasting in a new MAF table for it to work.
Old 06-27-2009, 08:32 AM
03Monte's Avatar
OK, after taking some time to figure out what exactly im doing, i made the following purchase from zzp yesterday.
XP cam with 105 springs/modded retainers
3/8 7.05 push rods
Modular pulley system (4.0)
104 spark plugs
180 tstat
clevite cam bearings (why not, cant hurt to have new bearings..)
This should be good for the engine, atleast for now...
by the time i get everything in the mail and the heads/SC are done (port/polish/valve job) i should have the money to buy the headers and exhaust and that should complete my mods (for the most part).
i also removed all of the interior, im replacing the carpet, and painting (vinyl dye) the plastics black and silver. i have the center console painted, and it looks great, im very impressed with SEM Color coat... i will post some pictures when i figure out what parts im painting silver..
Old 06-27-2009, 08:37 AM
You sure are acting your plan 4-Sure.
Would be great if you are taking B-4 & after pic's
It would also be great to see step by step on the interior mod's : )
Sounds like U R really improv'in your Monte
Look forward to all your updates, & hopefully
pictures. Wish you Good Luck on everything you are
doing. Thanks for posting/sharing.
Old 06-27-2009, 08:07 PM
3/8 7.05 push rods
104 spark plugs
180 tstat
Whoa- jumped into the cam huh? My reccomendation of the 104 plugs was figuring you were going to be just basic bolt ons, a cam/header setup would be better off with 103s IMO.
Next, definitely would ditch the cam bearings (awful lot of extra work for something that I've never seen go bad).
Third would be the 4.0" pulley- thats a massive pulley for a cam, even on 9.4:1 compression. You could run a 4.2" stock, a 4.0" is good for having a handful of bolt ons, but with a cam/heads/header/ported sc setup, you should be able to at least run a 3.4".
Lastly, what are you going to do about the timing chain? I'd at least reccomend sticking a new tensioner on there, do you plan to upgrade to a better chain?
Old 06-27-2009, 11:01 PM
03Monte's Avatar
Whats the major difference between them?
The guy doing the labor said, he might as well...so if he is doing the labor free, cam bearings is what he gets. (also, too late i already bought them)
The 4.0 is just to make sure i have no KR, as recommended earlier in this post. The main difference in pulley size is amount of boost correct?
Not quite sure yet, i wont be doing this install very soon so i have some time to decide.
My compression ratio will be changing a bit, the heads i bought from morad were warped slightly so now i have to have the head face milled down.
my understanding is that this will make a 9.45:1 when all is said and done.
Old 06-27-2009, 11:56 PM
103's are one heat range colder than 104's. 104's are great for L67's with basic bolt ons (rockers, intake, headers or plog/DP)- 103's are a step cooler for those in the cam/heads or IC range.
Honestly, in the middle of the post, it seemed as though you had switched to either not wanting to do any mods, or just doing some basics- hence the 4.0 reccomendation. It'll just mean less boost / less power than with a smaller pulley- I just hate to see the money go to waste (since I know it will be able to take a much smaller pulley)- I would call it ultra conservative for a setup like you plan to have.
Won't really make a difference, there are a few guys running 10:1 with M90's (and many running 9.5:1 with the forged piston builds), so another .05 compression ratio is no big deal, I doubt you'll even notice it.
Old 06-28-2009, 01:07 PM
03Monte's Avatar
I e-mailed zzp, i should be able to change these before they ship.
i did decide to run stock, i just couldn't get my head around exactly what i needed/wanted to do, but after reading a few post and talking to some very smart people locally i finally sorted out what i wanted to do... (im a network guy after all, engines seem more complex to me...)
im also changing this to a 3.8 if i can, still a little large, but im going to ease the pulley size down over time.
(this is for my comfort/peace of mind, and to make sure i don't blow this engine)
Yea, i didn't think so, i was just a little salty the heads were warped...
Old 06-28-2009, 03:56 PM
what kinda power is this thing going to make when its done? and no matter what its goin to feel like a change from day to night.
Old 06-28-2009, 04:21 PM
03Monte's Avatar
i wish i could answer this, but i wont know until the dyno tune!
Quick Reply: Starting to Mod my monte.
