Starting to Mod my monte.
Welp, i feel that from the information i have received here and a few other resources, i now feel i can make an informed decision as to what i want to do to my MC.
here is my list, in the order they will be done.
1. Rims/Tires - ASA AR9 (Black Accent) with Eagle F1 GS-2's.
2. Leather seats (Thanks to Erik at Morad)
3. 17k 4T65-E swap (again,Thanks to Erik at Morad)
4. L67 Top Swap with 3.4 pulley
5. INTENSE Supercharged/Blower 3800 Camshaft
6. 1.9 rocker arms (have not bought yet, still need more info on brand)
7. K&N drop in CAI
8. exhaust ( have not purchased, still debating Sound vs Price)
9. Dear god, i need a Custom tune...
10. Head unit and replacing the factory speakers/amp (haven't really looked, but as long as its not a crappy 1 ohm factory system im happy.)
11. sell my plasma twice a week and blood one a month.
12. Look at old savings account statements to "reminisce".
13. almost forgot, ubend delete (done)
Let me know what you guys think, i will post pictures of the before and after i get most of this done (should be in the next two weeks)
i would like to thank those who answered my Noob questions, and those who will answer my future noob questions (look out tuners, im headed your way soon!)
7. K&N drop in CAI
Hi Member 03Monte,
(no name location in your profile)
Sounds like you have a good plan for your `Monte : )
Keep us updated on your progress.
Giving `up to get the power you need/want/desire
Look forward to your updates.
7. K&N drop in CAI
I was going to point out that you can't use a K&N drop in w/ the CAI, and that you don't want to mix 1.9 rockers with an aftermarket cam, and that you're going to want more mods than just a cam before you run a 3.4" pulley on a top swap. Also that you're going to want to look into the exhaust BEFORE the catback in which case it's not really a question of sound versus price so much (sound isn't going to be affected much before the cat-back), but it looks like bumpin and chichi got it covered.
Anyways, if you don't have a good grasp of how the valvetrain works (or any part of the drivetrain for that matter), I'd strongly suggest looking up some info on howstuffworks.com or a similar site.
That way you won't end up buying mods that cancel each other out (or that are not compatible).
-Riggs.
-Riggs.
Sorry i haven't gotten back to you all, i have been busy with work.
after reading your posts i realized i was lacking some key knowledge to make an informed purchase and have been doing a little research.
This is what i have going on, i have the m90 blower with a 3.4 pulley already on it (came from morad that way) as well as the other pieces and parts required to do the swap (heads,intake, fuel rails, injectors...ect)
What im planning on buying.
1.180 Thermostat
2. Copper Core Spark Plugs 104
3. Roller Rocker Arms 1.9
4.Valvesprings (GVS-LS6 from intense if that helps)
5. K&N CAI (not just a filter)
6. Head will be ported and polished
7. Thinking about taking .005 off the heads for cleanup (don't know if i want to raise compression though)
Edit: 8. new fuel filter (i have ran nothing but cheap gas in this, i know those days are gone so figured it was a good idea to change the filter)
this is what i have narrowed this down to, how does this sound?
When i started this thread, it was supposed to be the mods i wanted, but because i t was 4am and it turned into a list of info everyone was throwing at me...
im not looking to build a car for the track, just have some fun (maybe even turn a mustang or two into glue.)
1.180 Thermostat
again, scratch that 3.4 pulley. I know it may have come that way, but if you are top swapping you CAN NOT be running a 3.4 pulley.
without a top swap the 3.4 is the most common pulley because you can achieve it with just the basic bolt-ons, but on a top swap, you'll be needing a 3.8 or a 4.0 with the basic bolt ons. So the first thing you should be buying is the 4.0 pulley.
The 180° will help
The rockers I don't think you will be getting roller rockers, but 1.9 modified stock rockers.
Which if you aren't getting the roller rockers, your 1.9 modified should be fine on your stock springs (correct me on this one bumpin' / riggs)
The K&N is good
A port and polish never hurts.
Now here is a nice list of things you should ALSO be getting:
ZZP Downpipe with U-bend delete and High-Flow cat (I know it's 3" for supercharged, so it should be the same for a top swap)
at the minimum you should get a Stainless Steel / Ceramic Coated front Powerlog
The best you could do is a whole set of headers though.
But most importantly DO NOT run that stock 3.4 pulley. Start at 4.0 until you can get it scanned for KR, and then try a 3.8.
The 180° will help
The K&N is good
I'm definitely buying a 4.0, anyone want to buy a 3.4
The 180° will help
http://intense-racing.com/Merchant2/...=3800-YTRR-yyy
this is what i was told to buy...is this wrong?
The springs are only $80, if it helps with only reliability then its worth it to me.
The K&N is good
at the minimum you should get a Stainless Steel / Ceramic Coated front Powerlog TBH, im not quite sure what this is
I have planned on doing this, Headers,downpipe, no cat though, no e-check here. and i already have the ubend removed.
The 180° will help
The K&N is good
I have to say this whole build has made me rather nervous.
If this post is wrong, someone should chime in, but if I were you.
Changing springs and valves from stock, actually hurts the reliability of your engine. I would get a set of 1.9 Stock Modified Rockers You can grab them at that link, or for about $150-$200 from clubgp.com/newforum. And with those you just have to put them in. No springs, nothing.
Here is a link for the downpipes.
and the front powerlog, if you aren't getting headers you can find here.
Doing all of these with the top swap, are very easy bolt-ons and should not harm the reliability of the engine, or be difficult to install.
What heads are you getting though? If you're doing ported heads, a cam wouldn't be a bad choice either- and could let you run that 3.4" depending on what cam and other mods.
