Starting 3.4L Timing Belt Replacement
Old Jan 1, 2007 | 02:18 PM
jogasz28's Avatar
Default RE: Starting 3.4L Timing Belt Replacement
ORIGINAL: benhillzone3
ao how long did it take to complete the whole job and greeat work glad that you got it going again.
I cannot give you an exact amount of hours as we worked on and off between my job,
family, and a million other things. I do know that it took 3 weeks from start to finish. As to hours
spent during that time, I'd guess it was in the 40-50 hour range. But remember, we had never worked
on this type engine before, so there was a lot of factory manual reading, asking questions online, searching
for answers. We also cleaned every part and the engine block, pulled the heads, replaced the oil pump
drive O-ring. When we started reassembly, we had to follow the manual for proper steps and torque
specs. If I had to do it over, it would probably take half the time. Remember also, that this is a hobby
to me, not a job, so I generally work at a comfortable steady pace.
jogasz28
Budsjlm
FWD Tech Guides '95-'07
Oct 29, 2015 05:01 PM
Dam20735
May 23, 2013 04:09 PM
fedspunisher
Nov 12, 2006 06:52 PM
jogasz28
Aug 1, 2006 12:01 AM
jogasz28
Jul 20, 2006 03:28 PM
