Starter Issue?
Old Oct 28, 2009 | 07:30 PM
Default Starter Issue?
hey guys, my cars been fine lately but today i got into my engine and kinda cleaned out the bay a bit because it was needed badly, but after that it started fine once, but the next time i went to start it, i just wouldnt start, and then right away after that it started, and that happened another time after that also, any ideas? could a low battery be part of the problem to a starter not working well?
Old Oct 28, 2009 | 08:14 PM
pilotknob1964's Avatar
When you say "wouldn't start", does that mean it would crank over but not fire, or it wouldn't crank at all? Did it just make a clicking noise? Need a little more info.
Also, when you cleaned out your engine bay, did you use water? And if so, did you cover all of the electronic stuff(alternator,connectors,etc.)? If not, water may have gotten where it isn't supposed to be and might be causing your problems. What's ironic is I degreased and cleaned mine today.(along with clay bar and wax job-she's smooth now!)
Old Oct 28, 2009 | 08:22 PM
it would crank over but just wouldnt fire, i didnt cover the electronics but i didnt spray by them either and everything was wiped down after cleaned
Old Oct 28, 2009 | 08:33 PM
MonteDriver's Avatar
not firing is a cause of a few things one of them is not working
1. spark-spark plugs, insufficient spark, bad coil, connection to coil not plugged in all the way or corroded
2. timing- probably not your issue unless you got something on a sensor
3. fuel- could anything be restricting your fuel or a loose injector connection
these are the things i would start investigating.
Old Oct 28, 2009 | 08:46 PM
if it keeps going im gonna check the spark plugs because i was drying around them, the water getting in places should effect any of the starter stuff tho i wouldnt think
Old Oct 28, 2009 | 09:47 PM
i just went out and pulled it into the garage and it started with no problems so i think its probably just some moisture that had to completely go away
Old Oct 29, 2009 | 08:18 AM
After you washed your engine and wiped it down, did you pop the hood and put it out in a sunny spot to dry?
Could have just been some moisture, always let that car dry fully before cranking it again.
Old Oct 29, 2009 | 08:59 AM
yea i had it open but i got a call and had to leave before it was fully dried
Old Oct 29, 2009 | 09:08 AM
let's call it moisture in the system right now, but if you have any problems from now on, I'd start diagnosing problems.
(probably starting by taking out each spark plug and making sure they look good)
rmorman
Oct 24, 2013 06:32 PM
thtGuy
May 7, 2013 08:09 AM
Double Deuces
Aug 27, 2012 12:35 PM
One Dark SS
Oct 12, 2011 02:09 PM
vampy1274
Aug 2, 2005 09:55 PM
