Standalone ECU for 3800
I don't see why not, LS people have done it before - especially for the people going for the retro look that put the coils on the firewall or frame.
Any reason you wouldn't just mount the coils on or above the valve covers though- LS style? Certainly a lot less to fail with only a few inches of high voltage vs a few feet.
Since that's a kit for a V8 you can save 110$ by buying the wiring and 6 coils separately
I think a major part you should have in hand or a connection to acquire for your build is the GMPP LSD or even Intense Racing had a LSD. But with out that key tranny part you will be severely restricted on the power you can put to the ground. I was lucky to have started my build when they were half way easy to still source out. Last one I found, looking to stash one away for a spare was $6500. I paid $2200 for mine back in the day, needless to say I passed on the spare. So before I committed like you appear ready to, you need to find that piece to the puzzle. As you may get the power and be breaking axles all day long.
I find it interesting and refreshing that there is another player out there at this phase of the Monte 3800 still willing to take on a build of your ambition. Not to many left out there, most blew up or people got tired of pumping endless amounts of money into the cars, sometimes the same part over and over. I'm on my 4th tranny refresh since 2008, never broke it, but preventative maintenance with new or improved parts will helpfully stave off a preventable catastrophic failure. Last time did a new converter, Precision of South Hampton 3800 stall. $1200, eats up the coin for sure.
I'd love to see that parts list if you don't mind. Also a couple questions regarding your build. What cam do you have in your monte? And how are cold starts with the dominator? Does the engine crank and then go up to 1300-1500 like a stock ecu, or does it crank and stay at idle rpm?
How's the traction control / boost by speed-gear? Are you able to just flat out floor it and let the computer handle the rest?
I've done some more research on the ignition side of wiring this thing up. To use the stock coils and bypass the stock ICM, you might be able to use part number 554-112, which is a four channel 2 wire coil driver. I say "might be able to use", because I'm not sure how only using three out of the four drivers would go. Since it's a four coil driver, you'd need two, but only run three of the four coils per driver. But I wouldn't go that route though. Upgrading to LS style smart coils is just a wiring harness. Stock LS smart coils, and all the aftermarket smart coils like Holley, MSD, etc., are plug and play. I also shot Holley support an email to see if the ECUs are compatible with stock 3800 cam and crank sensors. It'll probably be a while before I hear back though, considering Thanksgiving is tomorrow.
I get wanting a strong ignition, I'm just not sure you're going to have tangible gains with something notably stronger than stock LS given they've been pushed to power levels way beyond what any 3800 ever has, even when adjusted to a hp / cyl basis.
The other thing is that the stock 3800 pcm has proven to be sufficient to handle pretty big power - well over 600 whp, so I'm not really sure what extra this allows you to do at the power limits we're dealing with on this engine architecture. If the traction control / boost by speed was flawless, that would certainly be a big bonus for a serious racer, but I don't see any 3800 being competitive enough in today's world to make that feature alone worth the huge price of admission.
Just my .02 - not at all trying to put down Greg's build.
...this should get you in the ball park for your build.
Now that you mention it I do recall your thread about the alternate tranny. Followed your threads, you are a persistent devil, looking for the work around, nice going. Going to be waaay to much fun, but first the pain of getting it there. Sams 06 Monte I believe has the larger tranny, billet torque converter etc and would still break parts. But he was putting 1100whp down. They had to detune it down to I think the mid 800whp power level and now it lives well there. Matt had special parts for Sams tranny made during the trial and error phase.
Now Wolven here is on his mission and I'm excited to see his progress pictures, greasy beat up Fn hands, knuckles. You have got to applaud him for still being in the game when most others have long went home.
The cam you've got is definitely a custom grind. Comp Cams has three cams for the 3800, two NA, and one blower. (part numbers for those cams if anyone's interested: 76-800-9, 76-801-9, and 76-802-9) But none of them are rated to make power past 5500rpm. ZZP's discontinued ST1 cam was rated to make power up to 6000rpm, so I'm hoping the ST4, which is the cam I've got in mind for my build, will make power a bit higher than that. I'm thinking about shifting between 6800-7200 rpm.
Questions:
If you're still using the factory dash, how many of the gauges still work? Were there workarounds you had to do to get them to still work?
Are you still running factory fuel rails?
Do you know what your torque converter stall is?
Update w/ Info From Holley Forum
I've still been doing research on this topic cause I was unsure of the compatibility of the stock cam/crank sensors with the Holley ECUs. I made a thread on the Holley Forum asking about it, since I haven't received a reply from Holley's support team. A forum user there posted a reply linking this thread "HP EFI On 3800 V6 Engine". This thread has all the info needed to set up the Holley software using the stock cam/crank sensors, and LS style smart coils. It basically boils down to changing the firing order to get the cam/crank timing where it needs to be, using a 3x crank/1x cam type setup, and a couple other settings. The 3x crank is accomplished by only using one of the two crank sensor signal outputs. Which means the 18 tooth reluctor on the back of the balancer isn't used, only the 3x ring and it's output is used. This setup also allows the use of LS style smart coils, and the bypassing of the stock ICM.
I did read through the whole thread, cause I wanted to make sure I didn't miss any important info. I feel like I have to say that I'm very new to timing engines. I never learned the old ways of setting timing like with a SBC. So I may be missing a piece of the puzzle. But as I understand that thread I linked, there are no engine modifications to be made. The reason the firing order is changed is to get the cam sensor in the right position during the timing events for the Holley software to run the engine correctly.
I contacted the OP of that thread directly and he confirmed what I thought. There is no mechanical changes done to the engine. Everything stays where it was with the factory ECU. The change in firing order is used to get the cam signal "lined up" properly with the crank signal.
6th Gen ('00-'05): 3800 N/A Engine overhaul!!
hotrodss24
18
05-09-2013 12:17 PM
