Spark Plugs for a turbo set up?
Old Dec 5, 2009 | 03:37 PM
Wilco's Avatar
For being a small operation, Cartuning (Kevin) isn't on top of his game very much. I ordered a turbo from him about 10 days ago, just the unit since I got a used kit but the turbo unit itself was shot, and I'm still waiting!
Anyway, could you state the plug's nomenclature? Thanks!
Old Dec 5, 2009 | 04:54 PM
If you're going with Autolite copper plugs, you'd either be using the 104 or the 103 (103's are pretty cold, and would be better in a higher power setup).
Old Dec 5, 2009 | 11:15 PM
biggriggs's Avatar
from hottest to coldest it goes (for autolite copper plugs):
606
605
104
103
There's more options, but 606 is the stock heat range, and the 103's are what most people run on pretty extreme setups.
-Riggs.
Old Dec 5, 2009 | 11:55 PM
Wilco's Avatar
Since I'm having a bit of trouble getting a hold of Kevin at cartuning I'll probably try the 103's first and then the 104's, and see what develops. It should be fun!
Old Dec 6, 2009 | 05:39 PM
Honestly, I'd probably suggest going the other way- try the 104's first and see what the plugs look like.
Old Dec 6, 2009 | 06:33 PM
Wilco's Avatar
you're right, I should go with the 104's first. I'm going to be monitoring the engine anyway and I'll be able to check the timing and afr, and performed corrections as necessary.
bib12342004
Oct 27, 2014 12:12 PM
golfstud2k4
Jan 6, 2007 04:24 AM
2000_BLACK_SS
16
Sep 26, 2006 04:36 PM
2000_BLACK_SS
Sep 23, 2006 10:11 PM
bk4256
Mar 28, 2005 06:37 PM
