3.8 swap?
Old Dec 5, 2009 | 10:38 PM
96_Monte_carlo_LS's Avatar
Default 3.8 swap?
my car now has a 3.1 in my 96 , but i was considering swaping it out for a 3.8 out of an 02 impala, good idea?, bad idea?........ if anyone has any advice it would be appreciated
Old Dec 5, 2009 | 10:58 PM
skylark65's Avatar
bumpin '96 should be able to help you out with that one
https://montecarloforum.com/forum/sh...ad.php?t=14610
Old Dec 6, 2009 | 01:24 AM
nitehawkjcb's Avatar
Good idea. You'll need the motor, transmission, wiring harness from a 98-99 Z34, and both front axles(not sure if it's inner or outer) from the donor car.
Old Dec 6, 2009 | 10:09 AM
will the trans in my car work for time being?, and what would u recomend superchargin it?, or turbo?
Old Dec 6, 2009 | 11:13 AM
No, the transmission in your car will require a lot of modifications to work. It would be easier and cheaper to just get a 4t65e. You have a 4t60e FWIW.
Old Dec 6, 2009 | 12:09 PM
gothkid's Avatar
i love my 3.8 even tho it wasnt a swap
Old Dec 6, 2009 | 01:12 PM
Enzo354's Avatar
STILL SLOW
Turbo is very expensive, and if you want supercharger, just get one right away. Dont mess with the top swap, just drop in the L67 and the HD tranny.
Old Dec 6, 2009 | 02:18 PM
k can anyone point me in the right direction of a supercharger?
Old Dec 6, 2009 | 02:46 PM
Wilco's Avatar
You can try Morads. They have an ebay store and will ship to your door. Or you can check your local auto salvage yards for complete engine and trans set ups. I'd suggest going with an L32 S/C from an 04+ car. Better heat distribution from the S/C and more HP overall over the L67.
Old Dec 6, 2009 | 02:57 PM
i got the motor already out of an 02 impala, i was told the trans i have now would work without any mods if i jus do the 3.8 swap. then would it be best to find the proper transmission when i do the supercharger?
