Spark Plugs
RE: Spark Plugs
Fronts are a piece of cake, and the rears, aren't bad if you rotate your engine forward by removing the upper mounts, putting it in neutral, and rolling the car back and chocking the tires. HOWEVER, how many miles you got on it? You should be able to get 80-100,000 miles on your plugs before they get bad, if then. They just don't wear out. Coil packs will go out before the plugs, in my experience.
RE: Spark Plugs
ORIGINAL: RocknSS04
2000_BLACK_SS
16
09-26-2006 04:36 PM
