Spark Plugs
Old Nov 24, 2007 | 12:53 AM
03SS's Avatar
Default Spark Plugs
I have always worked rear wheel drive cars and never had to deal with changing the plugs on a horizontally mounted motor. How hard is it to change the spark plugs on these cars?
Thanks,
Steven
Old Nov 25, 2007 | 06:37 PM
RocknSS04's Avatar
Default RE: Spark Plugs
Fronts are a piece of cake, and the rears, aren't bad if you rotate your engine forward by removing the upper mounts, putting it in neutral, and rolling the car back and chocking the tires. HOWEVER, how many miles you got on it? You should be able to get 80-100,000 miles on your plugs before they get bad, if then. They just don't wear out. Coil packs will go out before the plugs, in my experience.
Old Nov 25, 2007 | 09:10 PM
03SS's Avatar
Plugs are still good I was just looking around the engine bay and those back plugs look crazy hard to get to.
Steven
Old Dec 1, 2007 | 04:32 PM
04 Intimidator's Avatar
ORIGINAL: RocknSS04
Definately the best way.
01blackmonte
Mar 20, 2007 10:06 AM
golfstud2k4
Jan 6, 2007 04:24 AM
2000_BLACK_SS
16
Sep 26, 2006 04:36 PM
2000_BLACK_SS
Sep 23, 2006 10:11 PM
bk4256
Mar 28, 2005 06:37 PM
