Serpentine belt size?
Old Nov 13, 2013 | 09:20 PM
sabre67's Avatar
Default Serpentine belt size?
My Monte calls for a (goodyear number)4060915 belt a friend has given me a brand new belt #4060910 belt. .50 of a inch shorter my question is will the tensioner have enough adjustment to use this shorter belt? Thanks
Old Nov 14, 2013 | 07:25 AM
We actually can't adjust the tension, you might be pulling too tight with that belt.
For the 5 minutes that it takes to swap belts, it's worth trying, but if you notice any weird sounds get the right belt.
Old Nov 14, 2013 | 09:06 AM
dbaldwin's Avatar
The tensioner pulley has a decent range of motion. .5 inches should be withing that range but may contribute to a premature pulley failure by putting extra load on the spring. Like chibi said, You hear a funky sound, change it.
Old Nov 14, 2013 | 01:49 PM
monte07's Avatar
the only time I know to go to a smaller size belt if there is a smaller sized pullies on the engine. if not go with the one that will least give you any problems like the original spec belt. belts are like tires and breaks and oil don't go with some thing that might mess up some thing big like a over heating issue or some thing on those lines.
Old Nov 14, 2013 | 02:10 PM
JC Colon's Avatar
Why did your belt seize? Before you put another belt on of any size, I would check your tension and all pullies. Something had to cause the belt to seize.
Old Nov 14, 2013 | 02:18 PM
dbaldwin's Avatar
Jc I think you missed something. I think his belt is just old and he wants a new one.
Old Nov 14, 2013 | 09:13 PM
sabre67's Avatar
Thanks for the replies,guys maybe I just better get the right size belt,was just trying to save a few bucks, Thanks
moonlitmagik
Dec 6, 2023 10:53 AM
KWJR86
Apr 8, 2012 09:30 PM
Stan MI
Mar 15, 2011 04:47 PM
Jack The Ripper
Jul 2, 2010 08:21 PM
rockin dude
Jun 12, 2010 08:43 AM
