rough starts
rough starts
hey guys, id say every 1 out of 3 or 4 times my car gives a real rough start. Makes the same sound like when you try to turn your key when the car is already started. Is this sparkplugs? bad timing? starter? the sound only lasts a second or two but kind of embarrassing when you go to start and it sounds like grinding metal.
RE: rough starts
also the starter might be lose on the mounting. if it has not done this in the past then all of a sudden started doing it then make sure it is still tight. \
\if it is or a new one then it might need some shims to make it stop that.
RE: rough starts
Not enough info about the car, but I would hit the basics: check plugs to make sure not fouled, verify wires secured, make sure air filter is clean. Swap out the fuel filter as you probably haven't ever done it to the car. and we will take it from there.
SgtWyatt
03-12-2012 09:44 AM
ChevRev34
02-24-2008 01:10 PM
Dispatcher7168
10-19-2007 10:37 PM
fedspunisher
04-05-2007 09:55 PM
