Rough idle when low on gas
Old Aug 19, 2013 | 04:58 PM
Video's Avatar
Default Rough idle when low on gas
So i think im finally on to something here. This rough idle keeps going away and coming back. Im starting to notice it happens when im down to 1-2 gallons. Then i fill up and it goes away after a few miles.
What the hell does this mean?
Old Aug 19, 2013 | 05:13 PM
Sounds to me like,
A:
Never run your tank down below a quarter tank...NEVER!
B:
Sounds to me like when your on E your fuel pump is picking up the residual sediment in the tank causeing it to no longer be able to produce the proper fuel pressure necessary to keep the motor running at top efficiency! Thus ending up with a damaged fuel pump that wil soon need replaceing.
Hope this helps...
I'm sure someone else will chime in with further information..
Old Aug 19, 2013 | 05:18 PM
Video's Avatar
Good advice. Its been tough for me lately money wise. Im gonna just have to take a good chunk of my paycheck and fill it up.
Old Aug 19, 2013 | 06:37 PM
03SSLE's Avatar
How long has it been since you replaced the fuel filter? Run a pressure test on the pump (connect tester where filter is) and a second test at the Schrader valve located at the pressure regulator.
Old Aug 19, 2013 | 08:50 PM
Video's Avatar
It has a new fuel filter only a couple weeks old. Ill see about doing a pressure test soon.
schmicr
Nov 21, 2014 12:43 PM
StanzManianDevil
Feb 22, 2009 11:28 PM
StanzManianDevil
Dec 24, 2008 06:46 PM
bigcoop_03ls
Mar 6, 2007 06:40 PM
mtmer1
Oct 24, 2006 09:54 PM
