Radiator fans stopped...
Old Jul 29, 2010 | 07:32 AM
PUNK LIFE's Avatar
Default Radiator fans stopped...
Hey monte owners, I was cruzing last night and suddenly noticed my engine temp was going up to half which it NEVER has done. I pulled over and discovered the fans were not coming on! Tested the fans and it seems there is no power going to them. Bad fuse? Ground? any ideas where I should start looking? Anyone experienced a similar problem? Oh yeah it's a 2002 ss.
Old Jul 29, 2010 | 07:57 AM
Half way on the gauge is only 195°, the normal operating temperature
212° and when the AC is on, is when your fans should be kicking on.
But definitely check your fuses
Old Jul 29, 2010 | 08:57 AM
Blazed SS's Avatar
IT HERTZ
or the engin temp sensor
Old Jul 30, 2010 | 02:27 PM
PUNK LIFE's Avatar
Thanks guys, I didn't realize normal operating temp was that high because I've never seen mine get there! Also they were not coming on while running ac, I had always heard that they should. I pulled two underhood relays first, they appeared to be good. Put them back in and the fan came on! I have no idea what to do now. I guess just continue to keep a close eye on the fans...after the weekend I will also get that temp sensor checked. Thanks again, you guys on MCF rock!
daves92camaro
Jul 15, 2011 10:10 PM
berettajeep
May 24, 2010 04:35 PM
starshinep
Jul 9, 2008 08:04 PM
monteriderLS
Jun 13, 2007 11:49 AM
04 Intimidator
May 5, 2007 05:09 PM
