Radiator fans stopped...
Hey monte owners, I was cruzing last night and suddenly noticed my engine temp was going up to half which it NEVER has done. I pulled over and discovered the fans were not coming on! Tested the fans and it seems there is no power going to them. Bad fuse? Ground? any ideas where I should start looking? Anyone experienced a similar problem? Oh yeah it's a 2002 ss.
Thanks guys, I didn't realize normal operating temp was that high because I've never seen mine get there! Also they were not coming on while running ac, I had always heard that they should. I pulled two underhood relays first, they appeared to be good. Put them back in and the fan came on! I have no idea what to do now. I guess just continue to keep a close eye on the fans...after the weekend I will also get that temp sensor checked. Thanks again, you guys on MCF rock!
berettajeep
May 24, 2010 04:35 PM
