Quick LIM question
Old Jun 5, 2009 | 06:30 AM
labnjab's Avatar
Default Quick LIM question
I'm going to be doing the LIM gasket on our 04 supercharged within the next month. I've done dozens of LIM gaskets on series 1 and 2 N/A engines but only 1 on a supercharged. I know on the series 1 supercharged 3.8 you didn't need to remove the supercharger to remove the lower intake. Does the same ring true on the L67? I'm just putting together a parts list and need to know if I need the plenum gasket and o rings. Thank you
Old Jun 6, 2009 | 09:08 AM
I'd take it off anyways, from what I've seen a lot of times the stock s/c gasket can get some oil soak from the pcv, and gets a little nasty around the egr port. Its only like a $5 gasket, so I'd change it too.
Oh, and if I were you, I'd do the aluminum LIM gaskets instead. They're a little more pricey, but I think they're a much better piece.
Old Jun 6, 2009 | 11:51 AM
labnjab's Avatar
Thank you. I'll take it off and replace the gasket just to be safe. Its not too much more work.
I didn't know they made the aluminum LIM gasket got the L67 but I'll get it. Good to know. I put the aluminum ones on my 99 Bonnevilles SLE
Old Jun 6, 2009 | 09:21 PM
http://www.zzperformance.com/grand_p...=290&catid=103
There it is in case you can't find it locally...
The_Maniac
19
Apr 20, 2011 02:11 PM
Rellsun
Sep 21, 2010 05:02 PM
pilotknob1964
Oct 3, 2009 01:53 PM
2000_BLACK_SS
Aug 21, 2008 11:12 AM
mcss01
Aug 4, 2005 10:19 PM
