LIM Torque specs
Old Sep 20, 2010 | 06:53 PM
Rellsun's Avatar
Default LIM Torque specs
Hey guys i know this has been discussed many times but does anyone have the new updated torque specs for the LIM. Ill be doing it this weekend and only have the old specs. I'm getting the Fel-Pro MS98004T Intake Set GM 3.1.
Also what do you guys think of this tool? Lisle Push Rod Remover 2.8L, 3.1L, 3.4L GM V6. I know a lot of people say it doesn't take much time to remove the rockers but i was thinking it would make it easier because i won't have to re-torque them preventing possible problems.
But the car is a 1997 Monte Carlo LS 3100.
Thanks for the input.
Old Sep 21, 2010 | 05:02 PM
Rellsun's Avatar
Hey guys i found these specs on http://www.gaownersclub.com/forum/showthread.php?t=74080 but they are for 3400 motor can anyone confirm that they are the same?
"Lower manifold...
1. Tighten the vertical lower intake manifold bolts (1) to 7N·m (62 lb in).
2. Tighten the diagonal lower intake manifold bolts (2) to 7N·m(62 lb in).
3. Tighten the vertical lower intake manifold bolts (1) to 13N·m(115 lb in).
4. Tighten the diagonal lower intake manifold bolts (2) to 25N·m(18 lb ft)."
kdkeith
May 21, 2012 01:50 PM
Shandley
Dec 12, 2011 07:07 PM
lui carlton
Apr 23, 2011 08:03 PM
Joe Thomas
Feb 24, 2009 07:28 AM
White05LT
May 15, 2008 07:16 PM
