Putting in a LS1
Old Aug 26, 2007 | 06:52 PM
lowlifez's Avatar
Default Putting in a LS1
I was wondering if anyone could give me suggestions on installing a LS1out of an 01 Cammaro into my 86 monte carloSS.I was wondering would it bolt up to the stock trans, what motor mounts to use, carb suggestions and radiator and cooling fan suggestions. I someone could pretty much give me the run down on what parts would be needed to convert the motor to carbuerated amd what would be neede for a succesfull install.
Old Aug 26, 2007 | 07:52 PM
RocknSS04's Avatar
Default RE: Putting in a LS1
Hello Nicholas and welcome to the Monte Carlo Forum.
I'm not up on the older Montes, but I'm pretty sure it's an almost bolt in mount, and Edelbrock makes a manifold and carb to fit these engines. My wife has a 5.3 LS1 in here '99 Z71 Silverado Sportside, and if your Camaro engine has as much ***** as this 5.3, it's a good swap. I've never been a fan of the older 350's, and the power from the LS engines is impressive.
http://www.cardomain.com/ride/2319272
Old Aug 26, 2007 | 10:36 PM
DESS03's Avatar
the thin you will have to find is a computer for it to put in your car because it is a DIS engine i think a company called FAST makes a computer for it to reasd the reluctor ring signal or they make a kit to turn in in to a normal igniyion system but that requires a lot of modification to the engine if you get the computer the rest of the instal will be easy a 650cfm carb would more than feed the engine
and gmpp has an intake for this motor to make it carburated
Old Aug 26, 2007 | 11:48 PM
2000LS's Avatar
i've looked into it before MSD and edelbrock make a kit that gets you most of the way there look up the
Edelbrock 7118
in jegs it sells for $710
looks like the kit includes a ls1 to carb intake, msd ignition that operates off the stock sensors and the harness to make it happen. and some throttle and tans. tv cable backets.
btw, on car-part i've seen a number of 5.3 engines for $550
yfz450tricked
Apr 6, 2008 10:31 PM
Jay84SS
Mar 18, 2008 04:33 AM
85ss
Nov 29, 2006 09:04 PM
tjnappy
Aug 19, 2006 06:35 PM
