putting 600HP into an 81' need advice
Old Apr 27, 2011 | 07:07 PM
scott.r.gray's Avatar
Question putting 600HP into an 81' need advice
so im looking at putting a 600HP engine into my 81' monte i know i will have to replace the transmition with one that can handle that kinda horse power and ive been told the differential too but im having a little trouble finding a differential here is the engine and the transmition i have picked out
Engine: Small Block Chevy 427 600hp 10.4:1 Complete Engine - eBay (item 190511309593 end time May-10-11 12:17:30 PDT)
Transmition: TCI Auto: 6X Six Speed Transmission Package; GM Bellhousing & Outlaw™ Shifter
i was also looking on advice as to what else i will need to do for the car to be able to handle that much horsepower.
Old Apr 27, 2011 | 07:54 PM
mrl390's Avatar
Your driveshaft and pinion, differential and axels all will probably need upgraded to handle the power. Not to mention your suspension will need upgraded or at least beefed up in the rear to handle the car on launches and burnouts. I would recommend upgrading the brakes as well to get that 600hp back to a stop in a safe distance.
Old Apr 27, 2011 | 08:17 PM
thanks, would you have any suggestions on where to find the parts and how do i know witch ones are strong enough to handle it?
Old Apr 27, 2011 | 08:58 PM
Budsjlm's Avatar
what are you plans for the car? strip car? street car? dual duty doing both?
Old Apr 28, 2011 | 09:16 AM
mainly street.
Old Apr 28, 2011 | 09:29 AM
Hi Scott, look 4ward to reading/seeing your updates.
Below is a link that you may find interesting & may help ?
Check it out then you have the time...Good Luck on your Project Monte Carlo...
High Performance cars, Project Car, and Sports Car Can Be A lot of Fun
... Not every car will make a good high performance car. When building a high performance car you need to think about what the car was designed ...
autorevival.com/?p=4552 - Cached
Old Apr 30, 2011 | 12:46 PM
sideways's Avatar
this is about the best deal on a rearend, they also have center sections and disc brake upgrades.9" Inch Ford G-Body Housing/Axle/Brake Package -Rearend | eBay
jgargano03
15
Dec 25, 2009 11:41 PM
mcarloss04
Jul 5, 2009 01:30 PM
thorpa2006
Apr 6, 2009 08:49 PM
lowlifez
Aug 26, 2007 11:48 PM
sinica9999
Feb 11, 2006 02:58 PM
