Pulley Size?
Old 02-09-2008, 07:02 PM
RocknSS04's Avatar
Default RE: Pulley Size?
Make sure that your Midas shop uses stainless pipe and nickel or stainless rod, or you're going to have a rusted out exhaust stsyem in no time. Most shops I've talked to use alumanized pipe and mild steel rod, not even mig or tig welded
Old 02-20-2008, 05:45 PM
Submariner's Avatar
ORIGINAL: RocknSS04
Good point I never thought of that.
Old 02-21-2008, 09:29 AM
ORIGINAL: Submariner
[sm=smokin.gif]
ZZP has a 3" downpipe with a magnaflow hi flow cat which is what I'm going to order. I plan on taking the Monte to my local Midas and have them replace the resonator with a section ofexhaust pipe.
Let us know how that turns out. I'd get my resonator removed if I knew it wouldn't create too much drone in the cabin.
Old 02-21-2008, 05:41 PM
ORIGINAL: RocknSS04
x10, I went through about 3 different exhaust setups on my monte because of this. When I do my swap's exhaust, its getting all stainless- that should last longer than the vehicle.
Old 02-22-2008, 02:48 AM
ORIGINAL: Nocturnx
[sm=smokin.gif]
I'm in the same boat. I like a quiet cabin for when I go cross country...800+ miles. The drone gets on your nerves quickly.
My SLP cat seems to quiet it down quite a bit compared to the RealTek one I had though.
Old 07-02-2008, 06:18 PM
Submariner's Avatar
[/quote]
[/quote]
No drone at all. I'm 46 andthe wife is 47 so if it was annoying she wouldpitch afit (Believe me she would). I drive 55 miles 1 way and can listen to the radiolow. When she is in the car I can listen toher talking at a normal level and still hear the radio.But outside from behind the car it sounds sweet! Sorry for the late response but I've been tied up concentrating on the other mods.
Yellowjacket
17
10-01-2012 07:58 PM
ParrottZ34
02-10-2008 09:06 PM
mcarloss04
07-23-2006 11:52 PM
nj85z28
01-26-2006 07:35 PM
maclawa
12-26-2005 08:40 PM
Quick Reply: Pulley Size?
