Is it possible to swap the 5.3 v8 from 06-07 into a 97 Monte Carlo?
Old Aug 3, 2010 | 11:37 AM
Dice276's Avatar
Default Is it possible to swap the 5.3 v8 from 06-07 into a 97 Monte Carlo?
Can someone help me out?
Old Aug 3, 2010 | 11:49 AM
skylark65's Avatar
probibly, the major thing would be finding one with a trans and the wiring harness.
"anythings possible with a sawzall and enough beer", lol
i've suprisingly never heard of one being done, but if you can get a compleate engine & trans & wiring harness, go for it. it'll be quite a bit of work though.
Old Aug 3, 2010 | 11:52 AM
mrl390's Avatar
It can be done but it will be ALOT of work. Alot of cutting and welding to get the engine to mount under the hood, then a TON of wiring to get everything to work.
Old Aug 3, 2010 | 12:52 PM
RickAKATed10's Avatar
Photobucket
Have a lot of money? Well if the answer is yes, it would probably easier and cheaper to buy a 06 Monte SS.
Old Aug 3, 2010 | 05:09 PM
seal0716's Avatar
Old Aug 4, 2010 | 12:17 AM
zipper's Avatar
I'll up your video to one that is more interesting
http://www.youtube.com/watch?v=XJKsDAhKusM
Plus I believe it runs 11's.
On topic, I wouldn't waste the money to do the swap. The general rule of thumb is that if you have to ask the question, then you are not ready/capable to install an LS4 into your 97 Monte. There has been a guy that installed a Northstar v8 (Cadillac) in a 5th gen Monte, but the swap was a pain and I believe there are still a couple of bugs even to this day with it.
An easier swap is the L67 swap. I recommend that.
Old Aug 4, 2010 | 09:02 AM
cbetts's Avatar
I remember people putting the NorStar motors in the 5th Gen MCs and Luminas when they first came out. Apparently it was a bolt in and just required some trickery for the computer.
Old Aug 4, 2010 | 10:02 AM
zipper's Avatar
The Northstar is far from being a bolt in. The engine uses different motor mounts, a different tranny (which uses different CV shafts), a different wiring harness, and many other differences that make this far from a "bolt in" swap.
It's an interesting swap, but it's a difficult one. You may have been thinking about the 4.9L V8 swap into the 5th gen Monte's because those engines used the same tranny (4T60E). Even that engine isn't completely a direct swap, but I would imagine it would be easier than the Northstar. The problem with the 4.9L V8 is that it only makes 200hp and 275 lbs ft of torque. Plus it has almost zero aftermarket.
If you're going to do that much work, you might as well install something that has much more potential, like the L67 swap.
Old Aug 4, 2010 | 10:11 AM
cbetts's Avatar
Didn't say my recall was perfect . . . ;-)
Any V-8 swap for a V-6 is going to be tough. The 3800 has a LOT of potential. Personally, I would go for the 3800 w/turbo or blower.
I get into enough trouble with my stock Z34 so I will be keeping it as is.
JoeD
17
Jun 24, 2014 03:01 AM
gtpshawty
Nov 7, 2013 03:04 PM
moomach
Apr 17, 2011 07:55 PM
shingding88
Aug 20, 2009 05:58 PM
jessymo
Feb 19, 2009 10:07 PM
