ported supercharger
Old Jan 8, 2014 | 03:18 PM
l67ss's Avatar
You joke but there is a guy on w-body.com(miko k) who had a turbo sc 3.8 5-speed in a 1st gen cutlass. Said it was a tuning nitemare lol. He dropped the sc and is now going just turbo.
How about super and turbo charged
Old Jan 8, 2014 | 06:31 PM
See, I've seen people that switched from a SuperCharger to a Turbo. I was joking about running BOTH at the same time! I think that might be just a LITTLE too much boost at once lol!
Old Jan 8, 2014 | 06:56 PM
l67ss's Avatar
I think he was running a 2.3l whipple and unsure of turbo. Sed it made an f-load of heat but not enuf power for the headache. Just running turbo now.
Old Jan 8, 2014 | 08:40 PM
Originally Posted by gasman
well i've got all the bells and whistles in my build. only thing left is headers or porting the sc maybe both
and my pully right now is a 3.25.
If your engine has all the bells and whistles, but you can only run a 3.25" pulley- then you're definitely missing something. I'd expect a 3.0" or smaller with all the standard mods.
What cam are running? Which IC? Ported heads? Which TB?
If you don't have headers or a ported SC- go for headers. What are you running for manifolds/DP now? Headers are proven to make power- but if you already have a PLOG and 3" DP, the gains wouldn't be quite as big as going from all stock.
Old Jan 10, 2014 | 06:23 AM
gasman's Avatar
i have the xp hot cam
-bigger throttle botty (high velocity one)
-bigger injectors
-short stack intercooler
-front p log
-full exhasut from down pipe back
-t stat
-plugs
-tuned from zzp
-springs/retainers
-fuel pump re wire
-intake
so i was getting headers next. but i was MAYBE going to get a ported supercharger at same time if it was even worth it. but i see its not i guess
Old Jan 10, 2014 | 10:09 AM
nitehawkjcb's Avatar
Wow... This is on a full L67, not a top swap? Something's not right. With that cam alone you should be able to run a 3.2, plus the SSIC should put you at 3.0 or below...
Old Jan 10, 2014 | 10:13 AM
Who's doing the tuning?
Old Jan 10, 2014 | 01:44 PM
gasman's Avatar
yea full l67. infact i got a dale earnheart jr car. zzp done all the tuening. i'm only guessing that they are giving me a conservative tune actually to make sure i don't mess it up. after headers/smaller pully/tune, i'll be working on my trans thats comming next.
fyi hp is 330ish 287hp at the wheels. and tq 320ish i believe
Old Jan 10, 2014 | 02:00 PM
I'd be pissed doing a cam and IC and not even having 300 whp.
Ever had it at the track?
Old Jan 10, 2014 | 08:42 PM
gasman's Avatar
Yea between light a and light b....
Also going 140mph down I 96
