Pics of the cracked flexplate
Old Apr 1, 2007 | 04:15 PM
76MonteMan's Avatar
Default Pics of the cracked flexplate
Here are the pics of my cracked flexplate. Any idea's on how to get
what's left of the plate off of the crank?
http://i75.photobucket.com/albums/i3...D/DSC05429.jpg
http://i75.photobucket.com/albums/i3...D/DSC05431.jpg
http://i75.photobucket.com/albums/i3...D/DSC05430.jpg
Old Apr 1, 2007 | 04:46 PM
TrickRacin's Avatar
Default RE: Pics of the cracked flexplate
WOW!! You cut that real close to disaster. Glad you cought it. Good luck with your little built up too.
Old Apr 1, 2007 | 05:18 PM
Mrrench's Avatar
take a chesile and and hammer.
go in between the flex plate and crank shaft, work it all the way around
it will come off
Old Apr 1, 2007 | 05:24 PM
mickey's Avatar
and uf that dont work get a small die grinder and cut it on both sided from the center tot eh top WITHOUT GETTING IN TO THE CRANK!!
then you should beabel to hit it with a hammer and it will fall off for ya that way also
Old Apr 1, 2007 | 07:08 PM
76MonteMan's Avatar
When I went to unbolt the engine from the transmission, two bell housing bolts weren't even hand tight and one was missing. That would probably be why it cracked in the first place.
Anyway, my dad and I worked at it for a little while and the remains finally came off. Tapping it with a hammer (not slamming it) and a prybar with some WD-40 and it slid off. I'm surprised that the plate didn't fly apart in that condition.
Old Apr 1, 2007 | 10:24 PM
Mrrench's Avatar
GM back then had a problem with the flex plates cracking.
I would say that the trans bolts are a result after the flex plate breaking causing a vibration.
Old Apr 1, 2007 | 11:22 PM
76MonteMan's Avatar
ORIGINAL: Mrrench
This wasn't the stock 31 year old flexplate though. This was a 3 1/2-year old plate with almost 50,000 miles on it. I think the flexplate cracked because the bell housing bolts weren't tight.
michelob
35
Nov 9, 2013 09:17 AM
02turbomonte
Jan 19, 2013 06:25 PM
2000_BLACK_SS
Jul 18, 2007 10:24 PM
76MonteMan
Apr 1, 2007 05:45 PM
jogasz28
Jan 15, 2007 11:42 PM
