performance trans
Old Feb 10, 2010 | 08:53 PM
Question performance trans
well im looking into a performance 5 or 6 auto trans any suggestions and prices installed?
Old Feb 10, 2010 | 10:47 PM
harvy's Avatar
what isthe least expensive mod a tranny 2002 3.8n/a shift kit or overhaul
Old Feb 10, 2010 | 11:36 PM
Wilco's Avatar
Shift kit would be the cheapest if you're going N/A or S/C. If you're going turbo then an overhaul of the trans and replacing the weak trans parts to support the mod would be a must. As far as the manual trans for an 02 Monty the OP may want to look around on line for that kind of conversion. It's a very expensive and complex procedure, with lot's of room to mess up. I only know of one person who has done this manual trans conversion and, according to him, it was a very expensive mod.
Old Feb 11, 2010 | 10:11 AM
MAMONTE's Avatar
Yea, the manual trans conversion is not really much of an option for MOST people.
Getting a 5 or 6 speed auto really is not much of an option either...in fact I don't know of any 5 or 6 speed autos that will bolt up in place of the 4T65E tranny you already have.
Your best option is to build your current 4 speed to handle extra power (they are actually really good trannies if built correctly), and tune the tranny for specific shift points to get a little more out of it.
Old Feb 11, 2010 | 11:05 PM
Why? What is wrong with your stock transmission? There is no trans that is going to be just a simple bolt in, plug in other than your stock tranny or similar. Not to mention, the only advantage of the higher gear # transmissions is so they can make the engines with a higher peak horsepower and higher peak torque, but with a much more narrow powerband. Since your engine was designed for the 4 speed with a fairly broad usable powerband, it doesn't make a ton of sense to add a bunch of extra gears. Plus, your stock transmission can handle plenty of power- you can build them up quite a bit if need be.
What are you asking here? Obviously a shift kit is way cheaper- the actual parts for the spacers can be had under $5, and you can reuse your stock gasket and fluid.
However a shift kit and an overhaul kit are for two totally different purposes. The shift kit is for alterning shift behaviour, an overhaul kit is meant to restore a used transmission to new.
08RedSS
Feb 18, 2013 08:43 PM
Yellowjacket
Aug 1, 2012 06:23 PM
skylark65
Dec 4, 2009 05:15 AM
montejass
Jul 10, 2005 09:18 PM
buddney
Jul 6, 2005 11:38 PM
