Performance Chip?
Old Mar 17, 2011 | 08:36 PM
krizneech's Avatar
Default Performance Chip?
I have a 2002 Monte SS and have installed Flowmasters and am looking for quick horsepower. I'm aware of the controversy surrounding performance chips, but let's just assume for a minute that they DO work. My friend said that before i do the chip i should upgrade my headers and a whole bunch of other crap in the engine. I think the flowmasters would be enough to relieve the pressure of extra horses. Any thoughts?
Old Mar 17, 2011 | 08:45 PM
Your stock exhaust was actually good for an additional 100HP.
https://montecarloforum.com/forum/sh...ad.php?t=10942
^ Read that thread ^
You have an L36
Old Mar 17, 2011 | 08:54 PM
krizneech's Avatar
So you think an extra 50 or so horses would be fine and not damage the engine and all the stock parts by putting too much strain?
Old Mar 17, 2011 | 09:00 PM
IDK how you think you are going to get an extra 50 horses. Just read the thread I posted and do a lot of reading.
Old Mar 17, 2011 | 09:05 PM
zipper's Avatar
First things first, "performance chips" do NOT work on our cars. Your best bet is to get a flashed PCM from ZZP or learn how to use a Powertuner or an HPTuner.
Second, 50hp won't hurt your engine if you do it right. Don't run the engine too lean or too rich and you also have to keep an eye on KR as well. It can be done, but if you keep the engine NA then it will be expensive to squeeze out an extra 50hp (been there went beyond that).
Now another thing to look at is just because your engine can handle the extra hp, doesn't mean that the rest of the car can. Our trannys are weak and they can fail with engines that are stock.
Check out the link that Chibi gave you, and that should send you in the right direction.
Old Mar 18, 2011 | 06:38 AM
krizneech's Avatar
Thanks for the help!
red03ssmonte
Feb 12, 2009 01:20 PM
1 Bad SS
Nov 15, 2007 01:08 PM
Yellow SS
Oct 5, 2007 02:40 PM
SirMonte34
Mar 29, 2006 03:18 AM
mcarloss04
Nov 19, 2005 02:59 PM
