6th Gen ('00-'05): Part Identification
Need some help with the names of these parts.
I pointed to them with arrows on this stock image.
I need the rubber peice where the 2 hoses go in and the a cap for the fuel on the top of the engine because its leaking.
The one in the back is a fitting for your fuel line (not sure of the technical name).
Now that rubber fitting in the front, not sure it's technical name, but it is part of that entire line assembly. Even though the lines pull out of it, it's sold as a set from the dealer. The rubber elbow at the other end dry rotted on me and only replacement was the entire thing (I think it was $20, I brought the old one to the dealer part's department).
Other option, hit a junk yard and pull it.
prickly_pete
Dec 5, 2011 03:39 PM
daves92camaro
Nov 20, 2011 01:46 PM
